Question about Plumbing
What do thermocouples measure? - Plumbing
What is a thermocouple
A Thermocouple is a sensor used to measure temperature. Thermocouples consist of two wire legs made from different metals. The wires legs are welded together at one end, creating a junction. This junction is where the temperature is measured. When the junction experiences a change in temperature, a voltage is created.
Thermocouple-Thermocouples-What is a thermocouple-Types of ...
www.thermocoupleinfo.com/
Dec 13, 2016 | Heating & Cooling
Small burner will not stay lit when it sparks
assuming this is a gas cooktop? It would be part of the flame failure safety most likely. There is a thermocouple that detects the flame and converts that heat to a small electric signal to tell the gas valve to stay open and/or closed.
A thermocouple is a sensor for measuring temperature. It consists of two dissimilar metal wires, joined at one end.
In the event the flame goes out, the design of the thermocouple is the valve would shut of gas supply to the burner.
In the event the thermocouple is faulty, check it is clean from carbon, and ensure it has not been bent.
Contact a qualified technician to get them to inspect further and replace thermocouple if required.
Nov 21, 2016 | Cooktops
Model wfs1273aw. What is the operating range of the thermocouple (ohms) in the heating element unit?
Hi Trevor
I guess it's open circuit so you can't measure it.
Does the thermocouple not have a part number on it?
I'll be surprised if anyone can provide an answer to this!
I take it that the thermocouple cuts the juice off to the element when it reaches a certain temperature. Or is it just stops the element from overheating?
Good Luck
Cheers
I'm Trevor also
Sep 22, 2015 | Whirlpool Washing Machines
What is a thermocouple?
The technical definition is a temperature-measuring device consisting of two dissimilar conductors that contact each other at one or more spots. Ive included a link and a photo for you to see as a reference
24D0808 Thermocouple
Jan 28, 2013 | Plumbing
Pilot light and heater will not stay lit
If the pilot light won't remain lit after you release pilot button you will need to replace the thermocouple. If you do not know how to do this it is generally a fairly easy job. First locate lines going from gas valve into burner compartment. There should be three, one to pilot light one to main burner and one to thermocouple. The thermocouple line is usually copper color and mounts directly in front of the pilot light. They usually slip into a friction fit holder so you disconnect line from gas valve and pull gently on line to remove. Measure length and get a new thermocouple at most hardware stores. If you can reuse the old holder then install thermocouple by inserting it into holder and seating it as far forwards as it will go. If you damage holder on removal there should be a new one with new thermocouple. Try to center thermocouple in pilot flame. Reconnect to gas valve and light according to instructions. I hope this helps you. Thanks
Nov 24, 2010 | Williams 2509612 Ceramic Mid-Size Heater
How to fix F7 in turbochef
F7: Thermocouple Open
CC Thermocouple
Reads 999?F/C or
IR Thermocouple
Reads 1999?F/C
1. Check the connection of open thermocouple on the I/O control board.
If the connection is OK, verify thermocouple is not an open circuit
by using your ohm meter. The cook cavity thermocouple should
measure approximately 4-5 ohms and the IR thermocouple should
measure approximately 30-40 ohms. Measure at the I/O control board
40-pin connector.
o Thermocouple indicates open circuit: Replace defective thermocouple.
o Thermocouple OK: Replace the I/O control board.
Oct 04, 2010 | TurboChef TORNADO Electric Oven
Two Gas hob burners will not remain alight
Does The thermocouple NOT hold at all or does it go out on low ? make sure the Flame heats the thermocouple , have you tried of disconnecting the Thermocouple from the Magnet and just clean the terminal on the T/C Have you measured the T/C Millivolt reading ? Have you got a clean connection on the Electromagnet ,Chech for bad solder joint in the Magnet
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Plumbing Logo
314 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
