Question about Euro-Pro Vacuums
Roller brush broke
I can't find a replacement beater brush anywhere. I tried superglue, but it didn't hold. All other parts to the vacuum are in working order. It's a Shark Navigator Swivel. The sticker on the back says UV410 26. Is this a lost cause?
  • Euro-Pro Master
  • 18,408 Answers
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
  • 75 Answers
SOURCE: roller brush of my dyson dc07 isn't turning...
it migh be the belt.check your belt or it is the brushroll is stuck.(from to much hair ect.)
Posted on Jun 30, 2009
VacuumRepair
  • 438 Answers
SOURCE: I need a new roller bar or beater brush for
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 14, 2010
SOURCE: shark navigator n22
What I tried and it worked for me is to losen the hose slightly from where it connects to the long plastic tube on the side to allow the little hole to show. What that does is to lessen the suction power a little since the problem is that the suction is too powerful on the carpet and the roller freezes.
Posted on May 22, 2010
Why is the brush roller on my shark nv440 not working
You most likely broke the belt. If you remove the cover to the brush/beater you will see where the belt goes to replace it.
Aug 11, 2014 | Shark Vacuums
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    The belt for the maain vaccume broke off and now with the new belt the roller will not work.
    It sounds like your roller brush itself might be bad. Try holding the roller brush holding just the end caps with your finger tips, and spinning the roller. Does the roller spin freely? If no, this indicates that your roller brush's bearings have melted together. This is a common problem for Bissell vacuums, as they use cheaper plastic bearing caps. The roller brush is not covered under the warranty either.
    When this part goes bad, this causes the belt to break almost immediately. If you tried replacing the belt, and it broke immediately, your roller brush has gone bad.
    Here's a link to the Bissell LiftOff Revolution rollerbrush on our site;
    Bissell Roller Brush for Lift Off Bagless
    Please leave me some feedback, or rate my solution helpful if this helped you fix your problem. Thanks so much,
    Chris Jones
    GoVacuum.com
    Jan 07, 2011 | Bissell LiftOff Revolution Pet Vac 37602...
    After installing belt...broke
    Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly.
    Sep 12, 2010 | Bissell 3522 PowerForce Bagged Upright...
    My eureka 5902 4D bagless uprights roller brush stopped spinning. The belt is ok. This model has a sliding switch for roller speed. The brush should spin when you release the handle via the foot release....
    The same thing happened to me about a year ago with this very model.
    The issue on mine was a small, copper-colored metal wheel that attaches to the end of the brush roller. You'll need to remove the top cover (there are several screws).
    Once it's off, you should see the belt, the beater brush, and the metal gear. The gear didn't fit correctly - so the motor just spins without moving the brush. I ended up going to the store and buying superglue that withstands high tempuratures, then gluing the gear to the motor's shaft... and hammering the thing into place before the glue 'set' too much. ...Not fun, but it's working and has been ever after. I can take photos of the thing if need be.
    Dec 23, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
    I turn the vacuum on and just make the noise like it's working and the brush is not moving.
    check the belt on the side of beater brush take out screws in the bottom lift up plate and check the belt it either to loose or to tight or broke. You have to replace them every so offend.
    Jun 28, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
    Beater bar belt broke. how do you replace it?
    Remove the glide plate, take out the brush and broken belt.
    Refit new belt and roller. re fit glide plate
    away you go
    Mar 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    No suction
    you still have a clog in there something is keeping the brushes from spinning. Be sure to remove any hair/string etc twisted around the brushes. Make sure the belt hasn't slipped off the metal pin behind the brushes, this is what creates the rotation. The brushes have a hard plastic molding on each end that fit into the sides of the vacuum. Make sure you have these on the right way or they will strip out and you have to replace the housing and the brushes. Have you cleared any blockages from the feed behind the brushes? Be sure to take the hose and extend it out and run a broom handle or something down it to be sure you do not have something lodged in there. Good luck .. if you need more detail post back. These can be rebuilt if needed, hopefully it is just something lodged further down the suction canal.
    Nov 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
    Vacuums Logo
    1,253 people viewed this question
    Top Euro-Pro Vacuums Experts
    Dennis Key
    Dennis Key
    Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
