Question about Electric Garden
Rolux magnum lawn mower
Will not turn over
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 18 Answers
Check the battery voltage..need a bit more info
Posted on Dec 31, 2013
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: need to replace to old blade with a new one on a
Disconnect the spark plug wire and ensure that the plug cap is some distance from the spark plug.
Remove the center cover cap (Pry off) and then remove the mounting bolt by turning it Counter clockwise while holding the blade to prevent rotation. Pull off the old blade and remove the center hub housing from the old blade. Transfer the center hub housing and install the new blade. Tighten the bolt CLOCKWISE while holding the blade until it is tight. Make sure you use a 6 point socket! Using a 12 point socket will result in the socket slipping and personal injury.
Re-connect the spark plug wire and your ready to mow again.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Rolux generator
put a bunch of nuts and sheet metal screw in the tank add muriatic acid just to cover loose metal. shake on all sides for 1 minute each side. Prevent leaking and wear rubber gloves and glasses. the rust will be gone.
Empty tank of all loose metal....reuse the tank
Nov 20, 2013 | Garden
How 2 mix stroke fuel for rolux lawn mower ratio
use the baby jug of 2 stoke oil the sell at your local mower shop, it will treat one gallon.
Nov 14, 2013 | McCulloch Garden
2 stroke oil mix ratio
the baby jug of oil you buy at the mower shop will treat one gallon of gas, use boat gas if you can find it it has no alchol. save the old jug and reuse it,if you buy in bulk, it's the safest way to ensure you get the right amount of 2 stroke oil in the mix.
Nov 14, 2013 | Garden
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
Cub cadet lawn mower won't start and i have changed everything
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Need to replace to old blade with a new one on a rolux magnum laser lawnmower but don't know how the remove it
Kelly
Mar 07, 2010 | Garden
No spark at plugs 14 hp kohler magnum
check the low tension lead, it may be shorting to ground by wear of the outer insulation!
Aug 12, 2009 | Garden
Need Parts/Service Manual for Toro HMR1600 mower.
Go to www.managemyhome.com and put in your model # for the manual (You can download to your computer). Also try www.searspartsdirect.com and put in you model # and you should be able to see all the parts for your mower.
May 16, 2009 | Toro Garden
Garden Logo
526 people viewed this question
Top Electric Garden Experts
Steve Oakes
Mike Squire
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
