doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
If you are blowing the breaker then you are pulling way to much current on the startup or you have a short in the unit...
either way you probably will be much better off by replacing the unit with a new one... they do not cost enough that it is worth sinking hundreds of dollars into fixing an old one...
your problem may be within your dehumidifier or it may be within the circuit breaker itself. I just replaced a faulty breaker this morning for a customer.
plug the dehumidifier into another plug which you are sure is working and also sure is not on the circuit you have been using. [turn that breaker off and you will know what it controls
if the problem is the breaker, replace it. if the problem is the dehumidifier look for a poor connection, a bare wire touching the frame of the dehumidifier, a fryed wire, etc. good luck.
It sounds like there is an issue with the controller board. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
