Question about Car Audio & Video
Ahuja amplifier circuit diagram
2n3773 transiter countinue sort
2 Suggested Answers
  • 84 Answers
SOURCE: circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Posted on Jun 14, 2009
Transit womt start had many parts renewed but stil havent sorted the problem
What age/ year?
Also it may need the ecu reset. If it has one .
Jan 22, 2014 | Vehicle Parts & Accessories
2005 Ford Transit not starting. Battery fully charged,engine turning over ok. Heater plugs ok and engine getting fuel. Anyone know what it might be. Engine relay problem maybe????
I have difficulty in starting my 2005 Ford Transit during the cold weather.There is no problem during normal temperatures.Are ther engine cold start heaters and where are they positioned on the engine.
Oct 27, 2010 | 2001 Ford Focus
Ford transit 02plate/fwd brake judder..ive had new pads/discs,cv joint,bearings,drive shaft.yet i still got juddering when breaking(not as bad as b4)garage says only thing left is faulty discs(very slight...
you mention replacing the discs/pads. how long ago? the fault described is usually caused by warped brake discs as you mention it comes on the onset of braking. i advice replacing the discs.
Feb 21, 2010 | 2002 Ford Escort
NEED INSTALLATION AND PART
i have installed a new bosch dishwasher...however there needs to be some sort of trim to transition between the washer and the wood cabinets...what do you suggest.
Aug 15, 2008 | Dishwashers
Transit brackets
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
Let me know if this sorts your prob
Regards Faggly
Mar 20, 2008 | Washing Machines
Cannot play the sound appears
Please Check your sound format.If it still countinues to give error then it contains some error.Thanks
Dec 21, 2007 | Sony Ericsson K800i Cellular Phone
Problem
L1:SCANNER UNIT FORWARD MOVEMENT PROBLEMS,POSSIBLY BAD SENSOR, SCANNER MOTOR, OR BOARD I would check that the transit screw that holds the scanner in place hasn't reconnected. The second thing is to lift up the glass and check that you can drag the scanning bit (the mirrored bit that moves) across. That should sort it.
Aug 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
Transitions
You should export your two video clips and make a transition in Windows Movie Maker. This is much faster and you have a wider selection of transitions.
Aug 09, 2006 | TechSmith Camtasia Studio for PC
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
