Question about Garden
Electric mower does not start
As you press the start button it makes a laboring buzz sound then a click sound then it is dead< it does not start
    Master:
  • 367 Answers
Check motor bushes ? (make sure power off first !)
Posted on Dec 30, 2013
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
A buzz sound when pushing start
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 17, 2012 | Maytag Dryers
Peugeot, speedfighter, electric start does not start when i press the break and the yelllow button on the right hand side, and rev it does not make a sound its lie the bike dead. But when the key is turned...
peugeot, speedfighter, electric start does not start when i press the break and the yelllow button on the right hand side, and rev it does not make a sound its lie the bike dead. But when the key is turned the petrol gage still rises, the horn indicators and everything else works
Jul 18, 2010 | Cycling
Kitchenaid gas dryer started buzzing when door is shut
May 17, 2010 | KitchenAid Dryers
Jcb electric mower just makes clicking noise wont start
some of these mowers have reset buttons on the motor---it works like a circuit breaker---access the motor housing to check for a button
May 10, 2010 | Acer Lawn Mower
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Gas dryer wont run
Hi. there can be many issue that can cause this type of interruption in normal operations. Lets go threw a few.One could be a faulty or dead motor. The timer board sends a signal to the motor once the start button is pushed. If the motor is malfunctioning or the wires that connect to the motor are lose or old and worn, the motor will usually click or buzz. the fault itself can be within the timer assembly or the motor itself. the best way to find out is to test the current flow at the motor by using a multimeter. connect this meter to the motor terminals and select the cycle and hit the start button. if the meter reads voltage at the motor and the motor clicks or buzzes, this will confirm an actual motor failure. if the voltage at the motor is weak or not there 0, this means the timer will need to be replaced. Next, I would check the door switch for its operational value. you can use the same method as i discussed above with the meter. use the terminals for testing on the switch. This could be a problem area as well. if the switch is malfunctioning, the dryer will not run at all. you will find the problem in one or both of the discussed areas above.
please rate and god bless.
Mar 25, 2009 | Kenmore Dryers
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
