Question about Acer NIC-559A PRO/100+ with Alert On LAN 2*
Drivers windows This driver shows a problem on my computer
    Champion:
  • 245 Answers
Try to find correct driver thru "hardware ID", in "device manager", and copy paste to google and find the driver and download
Posted on Apr 07, 2014
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Tip
How to install your monitor drivers in Windows 7 1. You will need to access your...
1. You will need to access your computers display settings. This link will show you how to access the display settings
http://www.fixya.com/support/r4290529-change_windows_7_display_settings
2. Click on "Advance Settings"
3. Click on the "Monitor" tab
Note here is where you will is if you have a generic drive installed or not. If it shows Generic or Plug & Play Monitor then you may not have the actual monitor drivers install.
4. Click on the "Properties" button and click on the "Driver" tab
5. Next you will want to click on Update Drive
At this point you will want to select "Browse my computer for the driver software". The reason you want to do this is because if you select "Search automatically for the updated driver software" you will most likely get the default Windows drivers that are already installed.
6. Next you will browse to the driver CD or the place you have the drivers saved on your computer. Note if you just upgraded from Windows XP your old drivers may not work and you will need to find Windows 7 versions of the drivers. However if you have a Windows Vista version of the driver this may work.
After you get the location set click Next
7. At this point you should get a message that states that the drives have been installed.
8. Click Close - Close - OK - OK and you should be back at screen resolution.
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Lenovo 3000 j115 multi card reader not showing up
hi, u must check ur cable in case. And uptodate ur win driver.
Jul 11, 2012 | Lenovo Computers & Internet
Need Windows 7 64bit drivers for Bluetiger BH-M20 Bluetooth headset
The driver will be available from the manufacturer. If there is not a 64bit version, it will not work properly. That will be the end of that then.
Jun 18, 2017 | Radio Communications
Need XP sata driver to install XP on a CQ5720F computer
From HP website seems that you computer supports only Windows 7. The drivers that HP shows on it's page are designed only for Windows 7 32 bit or Windows 7 64 bit.
The problem will be not only for sata drivers but for all components drivers. If I can suggest you I would install Windows 7 again, if you have troubles.
Mar 09, 2011 | Computers & Internet
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Acer Aspire M1640 shows a blue screen while installing windows xp pro
Mar 05, 2009 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
