Numark tt2400 I start the turntable and at the end of a few minutes rotation becomes unstable and stops. I wait a few minutes, the turntable works again correctly and stops again. is this a defect of electronic component or engine? Thank you for your answer
  • MARGUERIE DIDIER
    MARGUERIE DIDIER Dec 31, 2013
    Thank you for your assistance, I will seek the breakdown. I would return towards you to indicate the result to you. Merry festivals.
  • Audio Player... Master
  • 5,190 Answers
Sounds like an electronic fault. It could be bad solder joint if the turntable has had a recent impact or fall. Otherwise I would suspect a semi-conductor with a thermal problem - getting hot when it shouldn't. Check with your finger for hot parts! Don't burn yourself. If you find one spray with Servisol Freezer Spray. If the instant cool starts it working you have found the faulty part. If it doesn't then it's back to the drawing board!
Posted on Dec 30, 2013
djproaudio
  • 515 Answers
SOURCE: Numark TTX Turntable
Just so you know, there is no actual 'motor' driving the platter. It's a direct drive unit, so it's made up of various circuits driving the unit.
With that said, anyone of those circuits could have gone bad. The good thing, is that most of the circuits (resistors, IC's, capacitors, diodes, etc), are relatively cheap ($2-10), the bad thing is replacing them, and finding out which ones are faulty. You could usually tell which resistors are burnt or caps are blown, but it's harder to test the IC's without the proper equipment.
This is not a cheap turntable, unless you think $300 is cheap for a turntable. Repair wise, your probably looking at about $80-120 for parts and labor. It's a well build turntable, and I think worth investing in trying to get it repaired. Just make sure you get an estimate before any work is done.
- TWEAK AV LAB
Posted on Nov 26, 2007
djproaudio
  • 515 Answers
SOURCE: Numark TTX1 Turntable Problem-Platter stops
This is a drive issue. Unfortunately the TTX direct drive system isn't the greatest. It's good, but it's no Technics 1200. The only way to 'fix' this issue is to have a professional look at main circuit board to see if there are any components which are burned, or damaged in any way.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Posted on Nov 04, 2008
djproaudio
  • 515 Answers
SOURCE: cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
  • 69 Answers
SOURCE: Numark TT1 need to be manually started by moving platter
that'll be a blown component of some sort on your main board i think mate,youll wanna get some one handy wiyh a multi meter.gd luck
Posted on Aug 08, 2009
  • 3 Answers
SOURCE: i cant get one of my numark tt1550 turntables working
Check earth connection.
Posted on Sep 03, 2009
The Start/Stop button is not working property
I've checked the manual but could finf if your on/off knob is by a pcb tiny on off knob or do you really year a hard click. http://www.vinylengine.com/library/numark/tt1510.shtml login and they know it, it's easy to make
Jun 14, 2014 | Numark TT1510 Turntable
Received a Numark TT usb back in 2007. Just plugged it in for the first time ever. Installed EZ Converter on my powerbook, was all psyched to get going. The turntable powers on, but nothing happens when I...
Try moving the tone arm lever to raise the arm, if it has one.(MAKE SURE YOU HAVE RELEASED THE ARM CLIP!) Then with the arm raised move the arm over towards the platter. If platter still doesn't rotate, and its a belt drive, A. The belt is bad. or B. The belt has come off the platter or motor pulley.
Jul 31, 2011 | Numark ttUSB Turntable
Vintage turntable turns slow for few minutes then speeds up,,,why
The tubes are only in the audio amp portion of the stereo, and have nothing to do with the motor that turns the turntable.
Most likely it's that the grease on the motor is old and gummy, but becomes less viscous when it warms up.
Jan 24, 2010 | Numark TTX Turntable
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Feb 22, 2009 | Numark Pro TT-2 Turntable
CDX wont read any CDs
The CD transport (reader) is shot. These units are known for this! To date, they still havent fully corrected the problem. A band-aid fix is to buy a new transport thru numark or parts dealer.
Apr 13, 2008 | Numark CDX Turntable
Ttx 1 numark
hiya fixya...well i just opted,,,to take the thing to the repairs.the conclution is that the"platter rotation sensor " had burned out.sent the deck off today.will let you know the outcome,to maybe pass on this info to other ttx 1 users for near future....thanks for your responce.quote 35 quid just to confirm problem...but deducted from final bill of??????.westend dj staff are very helpful indeed where i puchased them from in the begining.
Mar 31, 2008 | Numark TTX1 Turntable
My decks!
do both of your numarks make the same sound? what is the weird sound? The magnet is 1 piece, so I am not sure if it has come loose - very hard to come loose. Check to see if there is any debris inside the magnet/coil area. Sometimes staples, small metal items get stuck to the platter. Just lift the platter off the turntable, to expose the coil and the magnet. If all is clear, then you obviously have a more serious issue. However, you will have to be more detail in describing what kind of problem your having: - Does your turntable power on? - Does it sound weird when you press the play button or does it make a sound even when the platter is not rotating? - This happening to both turntables? - Did you buy these units new or used? - If used, do you know the history of the turntables? - Does it affect the speed or playing ability of the unit? - Do you use the unit on the road? Move it around? - Did this just start happening instantly, or was it something that just got louder over time? I know it's a lot of questions, but I need as much information as possible to properly source the problem via this limited method. - Justin DJPROAUDIO
Jul 02, 2007 | Numark BATTLE PAK v.4 Turntable
63 people viewed this question
 Grubhead
Grubhead
