Question about LG HT302SD Theater System
How to connect mic to lg ht 302? - LG HT302SD Theater System
MIC NOT WORKING PLS HELP TO FIX IT
do a master reset and check mic socket on pcb...perhaps someone gave it yank while swinging the mic around in a rad karaoke evening!
Oct 16, 2016 | LG ht-356 region free pal/ntsc home...
Lg ht 310mv
Comute your home theater system from MIC to AUX or any other input source to get rid of that white noise.
May 07, 2014 | LG Audio Players & Recorders
Anybody knows mxl 990 works with behinger usb 302 mixer??
The user manual says Phantom Powered Mic input which means you should be able to use a condenser microphone requireing Phantom Power.
Mar 24, 2013 | MXL 990 Professional Microphone
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
How to use mic on samsung digital home cinema system
Knowing a model number would help a small way. But, the general answer is, home entertainment systems with cinema device. The microphone jack is for calibration of speaker balance.
Jun 23, 2012 | Samsung HT-Z310T Theater System
Dont know what size battery to use for a nady ht-3 mic transmitte
To insert the battery, You will need to unscrew the below button part of the hand held mic (anti-clockwise), and after unscrewing, you will see the space to fix in the 9 volt battery..
When you buy the battery,before fixing the battery in, check the polarity before placing the battery in (positive + and negetive -)...After inserting,screw back the cover in and locate where the power switch is..It always has an indicator to know if the power is on...
Note..make sure the Transmitter is on for it to be able to work properly with the hand held microphone....
Good luck..
Sep 07, 2011 | Nady Systems HT-3 Professional Microphone
I'm seeing a code "WL
i have the same problem with an LG HT 305SU and i don't know how to solve this problem, any help please?
May 19, 2011 | LG LHT854 Theater System
LG dvd model no: HT 302, doesn;t eject & if eject the cd manualy , disc doesn;t spin & the laser not coming on. what could be a problem?
there are switches needs to be in contact when the loading tray is closed and open. it is placed under the tray mechanism. investigate ribbon cuts and bends. replace it
Feb 25, 2011 | LG Televison & Video
I PUT IN NEW BATTRYS BUT NO GREEN LIGHT ON MIC . IT WAS CUTTING IN AND OUT BEFORE THIS HAPPENED. ITS LIKE THE MIC JUST DIED. CAN YOU HELP?
most likely a loose connection inside suggest,
check battery is held tight in place, if not then it might be possible to very gently bend the battery terminals just enough to help the connection.
if not battery connections then its inside the mic could be the power or the capsule wiring, need a tech or the dealer to take a look
hope this helps
thanks for using FixYa
Aug 15, 2010 | AKG HT 40 Professional Microphone
LG HT302SD Theater System Logo
16 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
