Question about Fujitsu 18C1 Air Conditioner
Inverter airconditioners Not heating up
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
What does malfunction code E6 mean in a koppel super inverter airconditioner
WHAT IS THE MEANING OF E4 code in koppel inverter split type
May 01, 2012 | Heating & Cooling
After an electrical storm knocked out the electricity for a few minutes, the airconditioner unit (LG inverter) has been flashing "CH" and "05" alternately. I've tried turning it off and then on again, but...
Hi; Try turning it off for 10 min. Then turn on and remember codes. I hope You still have a user manual You can sometimes find conditions exist with Your codes...Usually after a sudden loss of voltage the compressor will go into a time out so freon pressures can equalize...Thus not puting an excessive load on MR. COMPRESSOR...
Jan 20, 2010 | Heating & Cooling
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Hello have a inverter LG Airconditioner and it keeps turning itself off and showing the letters C6? Any ideas
Error Code: C6 Problem: Inverter compressor run current high
SOLUTIONS:
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s)
Probably best to explain/print out and give to authorised serviceman
Mat
Jul 14, 2009 | LG Heating & Cooling
Uneven air distribution through indoor unit
you should remove the indoor unit and send the gas to outdoor unit and remove the pipe line and start cleaning it.
Apr 10, 2009 | Heating & Cooling
Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
mintex007@yahoo.com
Feb 12, 2008 | Heating & Cooling
Fujitsu Inverter ASTA09LCC - heating not working
Use a pen to hit the reset button on the remote.
Feb 09, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 18C1 Air Conditioner Logo
16 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
