Question about Toshiba Libretto 50CT Notebook
Need to boot into BIOS to change IDE setting. No Floppy drive.
I accidentally changed the BIOS IDE setting for my Libretto 50CT hard drive from enhanced to regular. Now it won't boot up - I/O error. How can I boot the PC into the BIOS to change back? My floppy drive does not work, so I can't use the Companion diskette.
  • markyp00 May 20, 2009
    After pressing ESC during startup, it is also necessary to press the F1 key. I found this on another website, and it worked. I was able to make the change to the IDE setting. My Libretto 50CT is up and running again.
    Thank you for taking the time to respond to my inquiry.
    Problem Solver:
  • 14 Answers
Hi
To enter the BIOS during start-up press the ESC-key while switching power on
hope this helps :0)
Posted on May 19, 2009
How can i change the real time clock....
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
May 05, 2012 | Dell 038HRF GX150 PENTIUM-III SYSTEM BOARD
Booting method of libretto50ct
Best thing to do is,try to get a Windows 98 cd from a friend who has some computer skills and ask them to temporarily put in a cdrom drive in order to begin the process of repair.You will also need them to hook up a floppy drive in your computer,as you will need the floppy disk,containing the files to load the cdrom drivers and setup files to do the repairs to your windows 98 operating system....if not,you may need to upgrade to windows xp or Vista.Good luck:)
Apr 12, 2010 | Toshiba Libretto 50CT Notebook
Dell Dimension E520 problems Hello I have a Dell Dimension E520 PC. It boots up from the Floppy drive instead of the Hard Drive. I have changed the BIOS setting by disabling the floppy and have tried to...
In this case First Need to check in HDD Power is working perfectly or not then check Data calble is perfectly attached or not both side HDD and Mother board then check BIOS Setting and change settign boot piority make first boot from HDD
Mar 17, 2010 | Computers & Internet
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Hard drive does not hold windows xp
When you install windows and it's shows you 1 or 2 partitions, it's asking you if you want to DELETE partition, - say yes and delete all partitions you have, so when you done deleting all you'll have ~ 79GB of UNPARTITIONED spase. Only then, format as NTFS and install Windows.
Apr 05, 2009 | Fujitsu Computers & Internet
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard configuration
Serial ATA drives are pretty much plug and play. You just need to install them and set them up as a primary drive in your bios settings. The IDE devices can be connected on the same ribbon cable but need to have jumpers set on the back to determine which device is primary or slave. If the IDE devices are on different ribbon cables then most likely the hard drive jumper setting should be set to master or master (single drive). The CD-ROM drive jumper on master. BIOS should detect all drives You also need to assign the boot order in BIOS. CD-ROM should be the first boot device to load and install the new OS onto the primary hard drive.
Mar 20, 2009 | ASUS P5S800-VM Motherboard
ABit-Th7 raid Drivers
This problem is very simple.... Using RAID in booting in cd/dvd cannot be done in this kind of processing. you have to change the setting of Hard Disk and CD/DVD to IDE in BIOS . To change the setting in the BIOS you need to press the Delete After you power on the computer.. In Main menu in the bios you will find the hard disk or cd/dvd settings to IDE, SATA, and RAID. change both hard disk and cd/dvd to IDE configuration. make sure the first boot in the Boot menu is the cd/dvd, where your windows cd installer is inserted. Save the settings by pressing F10 key in the keyboard.. I have the same problem as of you because i try it to change SATA, RAID but cannot boot to cd and cannot detect the hard disk when installing OS, but in IDE settings its okay.. and it works perfect.. after you installed the windows properly, you can change the Hard Disk or cd/dvd configuration to SATA or RAID. TY
HOPE I CAN HELP
Dec 08, 2008 | Abit KT7A-RAID Motherboard
Power up problems
To enter setup (Refering to the bios/cmos), press the Delete key very two seconds untill the bios main menu loads. You need to go to the menu heading - Boot.
If you added another hard drive to you're system the IDE (hard drive) it's jumper settings may not be correctly set. If there are now two IDE drives both the primary master & secondary drive's jumpers must be set correctly. You will ned to look at the white sticker on the drive for the correct jumper settings. Many primary IDE drives pin jumper is set as a single master drive with out a secondayr drive attached in the system. When you add a second drive the pin jumper one the master drive will most likely need to be changed to master with a slave. The second drive will also need it's jumper set as a slave drive. Once this has been adjusted you need to enter the bios & make sure you're primary master drive is set in the boot order. Most PC's boot order is as follows.
1st Boot device, floppy drive. (If one is connected to the system).
2nd boot device, CD-ROM drive.
3rd boot device, master IDE drive.
Please use the help of you're manual to guide you for these settings.
AOpen MX46L web site. http://download.aopen.com.tw/Default.aspx
You must set the three drop down menu's to get you're board's drivers & manual. In the first menu choose motherboard, in the second menu choose MX46L & in the last menu choose manual. For drivers, the third menu choose drivers.
Still heave more questions? Just ask.
Mike
May 18, 2008 | AOpen MX46L Motherboard
Toshiba Libretto 50CT Notebook Logo
301 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
