I have a 250 GB, 5400 RPM SATA hard drive from a damaged Toshiba Qosmio G40-12C laptop, operating with a Core2 Duo T7500, 2048 MB + 1024 MB memory, 667 Mhz and 512 MB VRAM. My question is, can I slot this drive into any other Qosmio that is SATA? The reason I say this is because the disc drive in the old laptop is broken and I cannot use a recovery disc to access my data . So I need a computer with a functioning disk drive to recover the data from the HDD. I have already retrieved some data from it using an enclosure, but it says the C drive is damaged, so I need to use the special Spotmau software I have bought to try and get access to it. That needs a functioning disk drive The latest model I want to buy is a Qosmio G50, which has a 320 GB HDD, but I do no know if that would be compatible with the HDD I have already. Or can any SATA HDD be fitted into any laptop that is also SATA and still function. Thanks.
Comments:
May 20, 2009
- Thank you for the advice Chris - I will do as you suggest and see what I can get from the enclosure and recovery software. Have a good day.
Actually, there are two good reasons not to swap that drive into the new laptop,
First, you never want to boot from or install software to a drive you're trying to recover as everything you do to/with the drive runs the risk of causing further damage.
Second even if it weren't for the damage, you simply aren't likely to have the right drivers unless both laptops are the exact same model.
My suggestion is just get the new laptop you want, then attach the damaged drive with the enclosure to the new laptop then run your recovery software. If that doesn't work, you will likely need the help of a Pro.
Try Armor-IT Data Recovery, they are listed in the FixYa database and service clients from all over North and South America.
New Studio 15 screen went blank then computer froze. Power down then back up. Now screen is backlit...
(More)
New Studio 15 screen went blank then computer froze. Power down then back up. Now screen is backlit but nothing comes up.
Hi, i just bought and installed a new lcd on a satellite A105-S4254; the display comes up but i...
(More)
Hi, i just bought and installed a new lcd on a satellite A105-S4254; the display comes up but i don't see one big desktop, i see 4 mini-desktops on the screen. the intel 945 gm drivers are up to date....is there a monitor driver i need to install?? if so where can i find it....i got the lcd from screenaid.com
i have a toshiba satellite p205 model with an intermittent power problem. I already tested a...
(More)
i have a toshiba satellite p205 model with an intermittent power problem. I already tested a replacement ac adapter and also removed the battery, hdd and dvd. power turns on for 3 seconds then it shuts off. after like 10 times it turns on normally. it does not give enough power for video.
