Question about HP LaserJet 3055 All-In-One Printer
HP 3055 Print funny "asci" type characters
The printer is connect to the network and all users experienced the same problem. At first I thought one of the users used a wrong driver but it appears to be at the printer itself.
I have some other HP printer which gives me the option to reset defaults...I can fund it on this printer's menu. How can I do it.
Please help
    Novelist:
  • 125 Answers
Hi koos169:
Try these steps
Printing a configuration report, demonstration page, or menu
structure
1.
Press Menu.
2. Use the < or > button to select Reports, and then press .
3. Use the < or > button to select Config report , Demo page, or Menu structure, and then press
. The product exits the menu settings and prints the report.
Performing a soft reset
To perform a soft reset
1.
Press Menu.
2. Simultaneously press and then release the * button and the # button to open the developer's menu.
3. Press the < or > button until the message REINIT FFS appears on the second line of the controlpanel
display.
4. Press .
5. The process takes approximately 2.5 minutes. During that time, the control-panel display will
change several times before returning to Ready.
6. When the Ready message appears on the control-panel display, press Cancel to exit the
developer's menu.
Hope this helps
Posted on May 21, 2009
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Printer is on, does not copy, fax or scan, screen sez Hewlet Packard with right facing arrows.
Find and Fix Common Printer Problems Using HP Diagnostic Tools Review the following sections to learn about the diagnostic tools that HP offers, and then follow the links to learn how to download and install the tools. You can also use the following shortcuts to go to the section in this document that is related to your issue: HP Network Diagnostic Utility HP Print Diagnostic Utility HP Scan Diagnostic Utility HP Network Diagnostic Utility Network connectivity and communication is everything when it comes to networking your HP printer. The Network Diagnostic Utility provides help and information that is necessary to resolve network issues, including:
  • Verifies network and wireless connection status for your computer and the HP printer
  • Identifies security type and security key for your network
  • Identifies firewalls and supplies related help
Learn more!
Using the HP Network Diagnostic Utility (c02037530) (in English)
Oct 27, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Error code is 2753
Error #2753 is not a real code number for the HP 3055!
Please Visit here to check any other error codes regarding this machine here;
http://h10061.www1.hp.com/ccsearch/search?pname=HP+LaserJet+3055+All-in-One+Printer&qry=error+code+2753&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1140780&productBigSeriesOid=12012&spid=1140612&opname=HP+LaserJet+3055+All-in-One+Printer&pname_desc=HP+LaserJet+3055+All-in-One+Print%2FScan%2FCopy&ptype=commercial&stype=pn&contextual_lname=&spname=HP+LaserJet+3055+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&search=0
Good Luck!
Rich Lilja
Nov 13, 2008 | HP LaserJet 3055 All-In-One Printer
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
HP LJ 3055 Toolbox Not Connected
Hi SaveWetland!
Without being able to see your machine, I'm going to make an educated guess at your problem. Many times, when a printer is used over a network, only the printer driver itself is actually installed on each user's machine. Utilities, such as the HP Toolbox, may not be installed. If your network administrator allows it, you could download and install the complete printer software package off the HP website, which I'm highly confident would solve your issue. If not, I'd advise you to contact your IT person and have him/her install the complete package for you.
Good luck and I hope this helps. Please let me know, and also provide a rating if you deem it appropriate.
Bob
Oct 15, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
261 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
