Msi ms-7184 ati rs482 socket 939 motherboard stuck on hp invent
  • sammy8765 Jan 03, 2014
    i found the problem i disconnected the optical drives and hard drives from the main board and disconnected the power also restarted it and with my luck entered the setup then connected the hard drive restarted it and it booted it up on the hard drive no more hp invent then did the same thing to the optical drive and floppy disc one i did not connect was the cd optical drive i suspect it has a fault now the computer works fine solved my problem
  • 979 Answers
Hello Sammy, try pressing and holding the power button to turn off the computer. Unplug the computer from the wall and wait 10-15 sec. Plug it back in and power it on. See if that works.
Posted on Jan 03, 2014
3 Suggested Answers
  • 221 Answers
SOURCE: REPLACING MSI MS-7184 MOTHERBOARD - WHAT IS CORRECT REPLACEMENT
Any motherboard that matches the form factor, socket type(939), along with the front side bus. You must match all 3 in order for your new motherboard to work with your current processor. Otherwise you will need to buy a new processor also.
The following link will direct you to a page where you can purchase a motherboard that should work just fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131069
Posted on Apr 22, 2008
What the pins for the power switch, HHD indicator light, power light, and reset on an MS-7184 Motherboard.
Posted on Aug 06, 2010
MSI MS-7184 keyboard usb and ps 2
Sounds like your processor might be heating up too fast. I would take the computer apart, clean it removing all dust from the fans, check to see if the fan is actually spinning and check to make there the silicon glue has not dried up. It could also be that your power supply isnt supplying enough power but if you haven't added any devices that wouldn't be the issue.
Nov 21, 2013 | HP Amethyst motherboard MSI MS-7184 Socket...
Here's my system: MSI MS-7184 Motherboard AMD Sempron 3200+ 1.8GHz 2GB RAM Windows 7 Home Premium 32-bit Problem: I bought a Powecolor HD 4650 1GB DDR3 and when I inserted it in my computer. It...
Judging from the symptoms you describe I suspect that your graphics card is faulty. Did you buy the card new? If so, I would suggest returning it & asking the store to test it for you.
If it is determined that the card is not faulty, reply to this post & I will try to help you further.
Best wishes,
Graemevm
May 03, 2011 | ATI RADEON HD 4650, PCI Express Video...
Multimedia audio drivers
You can download the drivers from MSI WEB support site,select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
Mar 01, 2011 | MSI RS480M2-IL ATI Radeon Xpress 200...
I have a motherboard MSI k8 939, RS482, S8450 as i can see on the box. I lost my Driver CD. I need the drivers now. Help me out.
OK, this looks like your motherboard.
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=247
Socket 939, Chipsets RS482 and SB450.
There is a link for the drivers, manual, and more at the top.
Thanks for using Fixya.
Nov 19, 2010 | MSI RS482M4-IL MS-7191-040 (Retail)...
How would you know what type K8T Neo of motherboard you have mine just says K8T Neo
The manual is mostly the same.
MSI K8T Neo is also, MS-6702 (v1.X) ATX Main board. You'll find K8T Neo printed just in-between the first and second PCI slot.
In-between the second and third PCI slots you should see, MS-6702 ver 1.0 (Printed in white). All 5 models use the same chipsets. VIA K8T800 PRO Northbridge and VT8237R/Plus Southbridge. K8T Neo-FSR/ FIS2R Socket 939 use the same manual.
K8T Neo-V V2.0 uses a socket 754 CPU.
K8T Neo2-F V2.0 Also uses socket 754 CPU.
K8T Neo2-F-FIR Uses a socket 939 CPU
So open the link provided for drivers, bios ECT;
http://www.msi.com/index.php?func=searchresult&keywords=K8T+Neo&table=download
The most noticeable item is the SATA ports. From 2 ports and up to 4 ports. In different locations on the MB.
Did you find this helpful?
Mike
Jun 19, 2010 | MSI K8T Neo-FSR Motherboard
Want to upgrade to amd athlon 2
Hi........Socket 939 is an outdated processor and not compatible with Athlon 2. You may find a 939 dual core on ebay, but suggest you save up for an AM3 mobo. Hank
May 10, 2010 | ASUS A8N-E Motherboard
Any other brand will do the job as long as its a socket 939 but i strong recommend AMD Athlon 64 socket 939.
U can search for any socket 939 they will work.
Get bac @ me!
KJ
Apr 22, 2008 | ASUS A8N-E Motherboard
Apr 22, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
