Question about Canon P23-DHIII Calculator
Paper Loading How do you load a new roll of paper?
  • 2 more comments
  • Anonymous Dec 04, 2007
    Cant get paper to feed into adding machine
  • Barbara12 Mar 31, 2008
    I cannot figure out how to load the paper.
  • cbp564 Jul 19, 2008
    can't load a new roll of paper.
  • Anonymous May 14, 2009
    I can't seem to figure out how to load the paper. someone help.
Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
Posted on Aug 06, 2009
Put paper in the back and push the up arrow key
Posted on Jan 05, 2009
3 Suggested Answers
SOURCE: loading printer paper
Where I was guiding the paper, after feeding the paper through the back of the machine (the slot is located on the outside of the back of the machine), the paper naturally wanted to enter underneath the black plastic plate where it would end up underneath the entire printing mechanism. As the instructions indicate, the paper does not actually feed "under the black plastic plate", it should feed through it. There are two rectangular silver tabs, one on each side of the proper paper entry slot. I cut the paper at a very slight angle and finally found the magic entry point. Also if you make an arrow with the paper by folding the sides, it will help guide it in that tiny silver slot. Because the machine is so tiny, that entry slot is almost invisible, except for those two silver tabs. After you manage to insert the end of the angled cut through the "invisible slot" be sure the entire edge of the paper actually enters the slot so that when you push the "Feed" button, the paper is grabbed and fished through evenly. Hope this helps somebody!
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; document.getElementById("ga_300x250").style.width = "370px"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Posted on Oct 12, 2008
SOURCE: printer paper loading
Just achieved, after trying for 2 days
Paper should drape over like toilet paper.
Cut sides to form a point in the middle.
Feed through back of machine. Paper will have a tendency to point upwards.
Guide though metal roller, then hit feed........should go through.
Posted on May 13, 2009
Lift blue error
Typically the lift blue lever error comes up if the plotter detects skew when loading paper. If the paper cannot be loaded without skew then either you do not have the roll seated on the holder properly or the roll of paper was not made properly, which I have seen.
Feb 16, 2016 | HP DesignJet 500ps (42 in.) InkJet Printer
Loading roll paper for an Epson 7600
Remove paper, blow on the little window to the left of the bottom-right screw inside front cover...there's a sensor in there. I read this somewhere else, and it fixed my loading problems. Good luck!
Jan 08, 2013 | Epson Stylus Pro 7600 InkJet Printer
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Want to know how to load thermal paper on my sharp Fax model FO-71
1 - Grasp the finger hold and pull up to open the operation panel.
2 - Flip up the front paper guide.
3 - If you are loading paper that is 210mm in width, place the paper roll shims on each side of the paper compartment. (Note that Sharp recommended paper, including the initial roll, is 216 mm in width.) • The ribbed side of the shims should face in (toward each other).
4 - Unwrap the roll of thermal paper and insert the paper shaft.
5 - Place the roll of thermal paper in the compartment, making sure the ends of the paper shaft fit into the notches on each side of the compartment.
• Important: The roll must be placed so that the leading edge of the paper unrolls as shown. (The paper is only coated on one side for printing. If the roll is placed backwards, the paper will
come out blank after printing.)
6 - Insert the leading edge of the paper into the slot as shown. Continue to push the paper through the slot until it comes out the opening in the front of the machine.
7 - Make sure the paper comes out straight, and then flip down the paper guide.
8 - Close the operation panel, making sure it clicks into place.
• FO-71: A short length of the paper will be cut off.
Dec 01, 2010 | Office Equipment & Supplies
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Printer paper loading
May 12, 2009 | Canon P1-DHV Calculator
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Loading paper
I know this product and I have serviced it before.
I am a retired Xerox Service Representative.
Can you give me more details about this area.
I am not familiar, "by a roll of paper."
This machine can be fitted with one or two paper trays and has a by-pass feed tray, and a document feeder.
I do not know of roll paper that can be fed in this machine.
Thank you, I ook forward in hearing from you to resove this problem.
Mar 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
LOADING NEW PAPER
HOW DO I LOAD PAPER INTO THIS
Aug 10, 2008 | Canon P23-DHIII Calculator
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Canon P23-DHIII Calculator Logo
659 people viewed this question
old marine
old marine
