Question about Oral B Health & Beauty
Need manual for Oral B/Braum Type 3731 toothbrush
Need Manual
SOURCE: My Braun Oral-B Sonic Complete
I had the same problem today. I use the charging plug which has the "wrench" remove the bottom screw...I was attempting to remove the battery to reset the brush. I could not get the bottom of the brush off as I did not want to use a screw driver or similar to pry it off in case I needed to return the brush.
So I was trying to pull the bottom off and my finger was on the on/off switch, as I was wiggling the bottom of the brush to try to dislodge the battery it started working.
The brush seems to have a reset button on the back but that did not do anything. The display also has moisture trapped inside it, which I am sure is not good!
Any way try this and maybe the battery will come out and I am sure that will reset the brush...if not maybe you will get lucky as I did and wiggling it will work. BTW, this is with the Oral-B Triumph Professionla Care 9000
Posted on Feb 15, 2009
  • 3 Answers
SOURCE: manual for oral b professionalcare
http://www.service.braun.com/line/OC/O3745/O3745_2_NA.pdf
Posted on Nov 12, 2010
SOURCE: Braun Oral-B Triumph Professional Toothbrush won't shut off...
I think I may have just found issue with the problem, and that is that the inside of the unit has got wet. I suggest taking the casing off of the tooth brush and let it completely dry out, then test the unit. Hopefully this will fix your problem
Posted on Nov 20, 2010
aquaman987
  • 927 Answers
SOURCE: how long does it take
The first time you use the unit, it should be charged for 24 hours or more.
When it needs charging, my unit takes over 24 hours to fully charge and then lasts around 14 days until it needs another charge.
Is this helpful?
Gary
Posted on Mar 01, 2011
johndoe541
  • 784 Answers
SOURCE: My Oral B Vitality Sonic
ther is maiby some conection problems.
Posted on Mar 03, 2011
Do electric toothbrushes require a different amount of toothpaste compared than manual toothbrushes?
No, you should put the same amount of toothpaste on all types of toothbrushes. You should put enough so you can clean your teeth well.
Feb 04, 2013 | Health & Beauty
What are the popular brands of manual toothbrushes?
The two most popular brands of manual toothbrushes are Oral-B and Colgate. These companies pretty much control the market when it comes to manual toothbrushes. You can learn about their different manual toothbrushes at these websites: http://www.oralb.com/products/manual-toothbrushes/ and http://www.colgate.com/app/CP/US/EN/OC/Products/Toothbrushes.cvsp.
How often should I replace my manual toothbrush?
According to the Oral-B's website, manual toothbrushes should be replaced every 3-4 month because the bristles tend to become less effective for cleaning.
What are the different manual toothbrushes that Oral-B offers?
Oral-B offers six different manual toothbrushes. Check out this link to see what each toothbrush offers: http://www.oralb.com/products/manual-toothbrushes/.
What are the advantages of electric toothbrushes?
Electric toothbrushes are an excellent tool to keep your teeth clean and healthy. They offer many advantages:
They allow you to remove plaque more efficiently and quicker than manual toothbrushes.
You don't need to brush hard in order to get good results. This means that you are much less likely to injure your gums.
People who suffer from physical conditions like arthritis find electric toothbrushes as a great replacement to manual toothbrushes because they are easier to grip and you don't need to use as much physical power to get your teeth cleaned (the powered brushes do the cleaning).
It is more fun to brush with electric toothbrushes compared to manual toothbrushes, especially for children.
What are the different types of toothbrushes?
There are three types of toothbrushes that are commonly used:
  1. 1. Manual toothbrush
  2. 2. Rechargeable electric toothbrush
  3. 3. Battery power toothbrush
For more detailed information on these toothbrushes, check out Oral-B website
Jan 10, 2013 | Health & Beauty
3756 f 136 manual
The User Manual for the Braun Professional Care 500 Electric Recharegable Toothbrush can be found line here:
http://www.service.braun.com/line/OC/O3756/O3756_14_MN.pdf
Should this be helpful, please rate my assistance.
Thank you!
Jan 09, 2012 | Oral B Braun B Professional Care 500...
Lost instructions for use of oral b dual head vitality toothbrush
If you mean the Vitality Dual Clean toothbrush, you may download the manual here.
Dec 30, 2011 | Oral B Vitality Dual Clean Rechargeable...
My 5000 series tooth brush will not charge i tried it with a few adapters and still no result could it be the base or plug that is malfuntioning , i am an electrician and there is power in the socket so...
I have bought many rechargeable devices and about 4-5% of them have bad Chinese batteries in them. I also have converted nearly all battery operated items to rechargeables and these often have spotty performance with several out of a couple of dozen not worth keeping. You might try running the batteries down as far as possible and then trying to recharge. If they are NiCads, they may have developed 'memory,' a known weakness of that type and NiMh batteries in particular seem to need several charge/discharge cycles before they will come somewhat up to their rated capacities.
Mar 24, 2011 | Oral B ??? Oral b Professional Care...
Health & Beauty Logo
73 people viewed this question
Top Oral B Health & Beauty Experts
Jonathon summesfield
bayou sam
Are you an Oral B Health and Beauty Expert? Answer questions, earn points and help others
