"HP G85 UNABLE TO SEND OR RECEIVE FAXES - DISPLAYS - ERROR 00893947" Checked the fax cable connection, switched off, had fax line checked
all other functions performs Ok, copy,scan, print
HP G85. Lost small metal (aluminum?) clip and associated spring located near the ink reservoir port....
(More)
HP G85. Lost small metal (aluminum?) clip and associated spring located near the ink reservoir port. Causes severe loss of ink. Can they be purchased?
I have a HP G85 Officejet printer that has worked well for over 8 years. Only problem is that...
(More)
I have a HP G85 Officejet printer that has worked well for over 8 years. Only problem is that occasionally it will indicate "document failed to print" when I am trying to print something off the internet from my computer. The solution that works every time is to restart the computer and briefly turn off and back on the G85, it will then print out all the previously requested print requests from memory. Is there an easy fix for this?
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use...
(More)
can i upgrade memory in hp officejet g85, for some reason it has stopped printing pictures? It use to print great pictures & now it has quit. It prints about an inch of a picture & then spits our the paper. I am using vista 64, i have tried to print in kodak easyshare, photo gallery, hp print software & gimp? Any suggestions? **** I did just submit this same question, but forgot the g85? so see repeat question
can i upgrade memory in hp officejet. For some reason, my printer will now only print the first...
(More)
can i upgrade memory in hp officejet. For some reason, my printer will now only print the first inch of a picture & quits. So I was wondering if I was having a memory issue or who knows? It use to print pictures just fine. Suddenly its sick. Can you help
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
