Question about KitchenAid KSRD25FK Side by Side Refrigerator
How to remove stuck ice bin - KitchenAid KSRD25FK Side by Side Refrigerator
My lg side by side refrigator ice maker it will make ice but doesn't always come out of the tray
About once a week, I have to take the ice bin out and empty the ice in a large bowl, remove the stuck-together pieces then return the ice to the bin and replace the bin. Good luck.
Feb 12, 2017 | LG Refrigerators
I need to know how to remove the ice maker compartment to throw out all old cubes.
Hello Karla Shelton,
A wee little ice can LOCK your ice bin in place!!
How to remove the bin would depend ENTIRELY on
the MAKE & MODEL of your refrigerator...
They key to success... BE GENTLE... even if the freezer
has a solid grip (frozen in (more common on door bins)).
If it is stuck good & solid... BEFORE you decide
to take a PRY, Crowbar or WRECKING BAR to your
ice-bin... think soft breakable "PLASTIC"...
BETTER to DEFROST your entire refrigerator
than to break that bin.
Check your parts/spares retailers to see if it is even
POSSIBLE to REPLACE...
Never use a HEATER on the soft plastics.
Patience & care...
Make sure the bin is clean & dry before putting it back.
Hope this helps.
Search Over 2 1 Million Appliance Parts
Sep 07, 2016 | Refrigerators
When crushed ice is selected it will continue and not stop
auger stuck remove bin check for ice build up behind bin or in bin clear make sure lever moves freely on bin& auger relay at rear if its a ling bin unit .
Mar 16, 2015 | Frigidaire Refrigerators
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
Crushed ice mode seems stuck - want cubes but keeps crushing.
jeff, at one time the ice bin was removed and there is a rod on the bottom of the bin remove the bin and you'll see an opening where the arm will fin the square plastic looking assy is probally stuck in the up position pull it down with you finger and reinstall the bin the it should work
Aug 19, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
GE Monogram refrigerator ZFSB26DRE - ice bin stuck
their has to be a release botton on it look around inside
Jun 06, 2009 | Refrigerators
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
KitchenAid KSRD25FK Side by Side Refrigerator Logo
37 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
