Question about LG Washing Machines
Spin timer not working WP-9033 model(LG washing machine)
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: MY SPIN MOTOR IS NOT
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
SOURCE: LG Model WP-9241 Washing Machine - Wash tub ok but
i am getting problem in spin unit pl give us manual of it for repair
Posted on Nov 07, 2010
  • 6277 Answers
SOURCE: the model of my LG
Sorry but your description of 'isn't working' has very little detail in it so I am trying 'poor water fill' first:-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Aug 14, 2011
LG Model WP-9241 Washing Machine - Wash tub spins in only one direction
wash tub spins in only one direction it cannot spin in other direction
Dec 21, 2014 | LG Washing Machines
LG top loading washing machine spin not work n
Try test your lid switch. If the switch is inoperative, the machine will not spin or drain when it gets to that cycle on the timer
Sep 25, 2014 | Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
I have an lg 5kg washing machine WD-80264NP which stops after washing for while.it doesn't spin. what could be the problem?
Ur timer switch for washing/spinning is broken, there are contact points on that timer switch, the part of SPiNNiNG is not functioning!
Let a technician check on that, and might as well replace it!
Nov 29, 2010 | LG Washing Machines
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
