Question about Video Game Consoles & Games
Ps3 joystick Move the Left joy stick forward and console doesn't respond.... Four diff controllers all the same issue. Every other function works fine. Way confused at this point why the ps3 is picking up all other signals from the controller except for the up movement with the left stick. Please help if you can. Thanks
    Master:
  • 366 Answers
Calibrate controller ? check controller settings ?
Posted on Dec 30, 2013
SOURCE: PS3 Controller Jams
Have you found a solution to this problem? I have the same issue for the right stick. I played the SKATE demo a couple of times and that exaxt thing happened to me. Help please.
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: Sony PS2 controller left side directional button inop
i know what you mean try pulling the button and then on the game on menu change the controll or buy a new one in game stop for $15.00
Posted on Mar 15, 2009
  • 86 Answers
SOURCE: Xbox 360 controller left analog stick
If you bought it brand new, contact Microsoft ASAP.
Otherwise, no luck. Just an unfortunate side affect of playing a 360.
Posted on Apr 10, 2009
TimIsHectic
  • 39 Answers
SOURCE: Xbox 360 Controller Functions (Sticks and Buttons)
That's a manufacturing fault. Take it back to where you bought it or get in touch with Microsoft (who will probably replace it for free)
Contact Microsoft
Posted on May 03, 2009
  • 71 Answers
SOURCE: please help asap!!!!!!!!!!
I would suggest to toggle the "analog" button on and off to see if that fixes the problem. If not then try a different controller. Try it with different games as well(make sure discs are clean!!) If that does not work then your playstation has a malfunction and needs to be repaired if it is worth it to you.
Sorry!! GOOD LUCK!!
Posted on Jun 11, 2009
On cod my logitech controller's control pad moves my player but i cant move with the left joystick (they have been switched somehow)
You have to go through the game settings and ensure that you have set the primary control to be done by the left analog stick. In other words, make sure that you have the left-analog stick as the tool to move your player around while playing the game.
Also, if that doesn't work, there is a possibility that your left-analog stick is somehow jammed and as a result doewsn't perform the right function.
This could be a factory fault or one that arose as a case of mis-management. Whatever your result is, kindly let me know.
Hope this solution was helpful? Please comment for more information and thank you for using www.fixya.com
Jan 02, 2011 | Logitech Cordless Precision Controller for...
Damages joy stick, cannot move up, down, left and right
Most of the time joystick problem can be corrected by :-
-put some servicing liquid like petrol on joystick area and move your joystick up dpwn left right
then dry your board .
- most of the time this problem will be solved by this process. if not then change your joystick
Oct 20, 2010 | Sony Ericsson K700
Power good, but no motor functionality - Jazzy Select
hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked
Jul 04, 2010 | Pride Jazzy Select 6 Indoor Power...
The rubbre part on the joy stick turns
Just pull it off very carefully try not to tear it, then put a small amount of super glue on the top of the hard plastic joystick. Put the rubber back on, let dry for 2 hours and good to go.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 SCROLLS DOWN AND WONT SCROLL UP!!
This kind of thing happened quite a bit on older gaming systems if the joy stick was tilted while booting. If this still happens when you leave the controller sitting on a flat surface while booting, the joy stick sensor may be a bit stuck - usually you can solve this by clicking down on the left stick and or moving it somewhat violently for a few seconds. If that doesn't do it try a silicon based lubricant, wet a section of cloth with it and then wipe it on the exposed based of the joy stick - move it around a bit to get it inside and try it then.
May 30, 2009 | Sony Playstation 3 (PS3) Console
How do I lock up my Hoveround MPV5? The tech that delivered my chair shown me a way to lock up the joy stick & wheels, I don't remember how he did it and can't find my manual.
1. Turn the controller on.
2. To lock the chair, depress and hold the ON/OFF button. After one second the controller will beep. Release the ON/OFF button. Move the joystick forward until the control beeps. Move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is locked.
3. To unlock, turn the control system on. The speed/response indicator will be rippling up and down. Move the joystick forward until the control beeps. Then move the joystick in reverse until the control beeps. Release the joystick. There will be a long beep that indicates the controller is unlocked.
This is from the manual, I hope it helps you.
May 06, 2009 | NRS Hoveround MPV 5 - Used Power...
Logitech Freedom wireless joystick
i have had similar problems... it might be the disk also if the disk is really old it might not play properly becuase your computer is to new.but if that isent the problem your joy stick might only hook up to a desk top if you have considered these issues and nothng seems to effect it well ... get a joy stick that needs to be hooked up ... hope i helped
Jul 27, 2008 | Sony Logitech Freedom (vs9632830403)...
PS3 Controller Jams
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Joy stick
you need to clean the joystick. Sometimes just a pressured air can can solve it.
Sep 24, 2007 | Nokia 6600
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
