Question about Motorola Mobility RAZR V3i Cellular Phone
Samsung sph-m280 screen went blank - Motorola Mobility RAZR V3i Cellular Phone
The screen on my My Samsung SPH-m510 just went blank, white. I am able to receive incoming calls, however i have no means of seeing anything that is on my display, need it be main screen, contacts,...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Jul 23, 2010 | Samsung SPH-m510 Cell Phone
How do i replace a lcd screen on a sph-m520 samsung cell phone?
You may click the links below.
http://www.tradekey.com/selloffer_view/id/3270130.htm or call 1.800.SAMSUNG
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Samsung SPH-m520 Cell Phone
Samsung SPH-M300 display screen is white
your screen is broke you need a new one or buy a new phone the same thing happen to me with the same phone and it cant be fixed
Mar 14, 2009 | Samsung SPH-M300 Cellular Phone
Screen went blank
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Or it is liquid damage
Mar 12, 2009 | Samsung SPH-m520 Cell Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
