Question about HP CA340 Digital Camera
Where do I insert the memory card? - HP CA340 Digital Camera
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I am getting no memory card inserted
Remove your battery
insert your memory card
insert your battery
Power On.
if still no memory card inserted
Replace your memorycard
something wrong with your memory reader (parts of cellphone)
Jan 19, 2013 | Nokia N73 Cellular Phone
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
Jun 18, 2011 | Samsung Star GT-S5233 Cell Phone
I will put memory card in my mobile no memory card inserted
First of all,make sure that you're inserting the approved type of memory card.
According to nokia company,nokia N70 supports for RS-DV-MMC cards.
If you're using the correct card,make sure the card is clean enough.You can clean the card by using a soft dry cloath like cotton cloth-DO NOT USE ANY LIQUID-.
After doing so,re-insert the card and check.
If the above step doesn't helps,insert the cleaned memory card into a card reader and check whether the computer can open the card.If it can,backup all the data on the memory card and format the card.Then insert the card into the phone and do a format to the card againg via phone.After that you can restore the data back to the memory card.
If all the above methods didn't work,then may be your memory card is burned out..
Jan 11, 2011 | Nokia N70 Cellular Phone
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
When i insert my memory card in the slot than the phone didnt show the memory it tells insert memory card..........
The memory card is not good, please, try and change the memory card and insert it. Thanks
May 20, 2010 | Lands Phones
I have re-inserted my memory card of Nokia N73. but is showing "memory card not inserted"
ur memory card may damaged or used password in memory card. pls check other phone to confrm
Jan 11, 2010 | Nokia N73 Cellular Phone
Get Memory card not inserted
simply check the memory card through card reader if it works then u have to check the socket of phone where the card is to be inserted..
that one is causing problem...may be its pins are not propely being connected with the memory card..
if  the card doesnt work even with memory card reader then the card is faulty...or if u dont have memory card reader just put your memory card in another compatible phone to check..
or get another card and put it in your phone for checking..
hope it will fix the issue so dont forget to rate it...
Jul 06, 2009 | Nokia 5800 XpressMusic Smartphone
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
HP CA340 Digital Camera Logo
24 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
