Question about Nokia 5310 Cellular Phone
Memerry card formatt ayi poyi
How to get memrry card install
It is very easy to install a memory card in to your phone enter your memory card where the space is provided and push the memory card but aware of the fact that not to push it tufly push it smoothly and keep golden plate inner side
Posted on May 25, 2009
I can not log into my AYI account becouse facebook froze my account by getting my date of birth wrong
You really have to solve this with Facebook. If you inform Facebook, someone did hack your account, they could send you a reset code to one of the old return addresses, if you did setup your security correct. We don't have links to Facebook, nor do we have contact to AYI or paypal, so all problems should be tackled with these sites, separately. We try to help people by answering questions, we don't play judge or jury when there are disputes.
Dec 30, 2014 | Facebook Computers & Internet
Delete ayi dont
Hello You can block emails from ayi.
May 28, 2014 | Facebook Apps
My machine is powered up but the screne does not have anything displayed. All the lights (ready, data, attention) are lit up.
The last time I ran into this problem it was a faulty formatter. Your first step is to remove the formatter and reseat any memory dimms or cards on the formatter. Always power off printer and unplug before removing/installing the formatter. If pirnter does not start after reseating memory, unplug printer again and remove formatter and start printer without formatter installed. Once you have powered up the printer, look for a small hole on the back of the printer, Upper left side if you are infront of printer, right side if you are facing the back. Use small object like paper clip to push the button which will generate an engine test. If it prints, then the formatter is most likely bad, but firmware on formatter may also be corrupt.
Jun 01, 2011 | HP LaserJet 4700 Printer
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
All control panel light on. nothing on the screen. can't print
Make sure that all of the buttons on the control panel are not stuck in the in position, other then that this usually will indicate that the logic of the formatter has been damaged and the formatter will need to be replaced... They are a snap to install, just 2 screws hold it to the machine then you would slide it back until it disengages from the machine. If you do end up needing one you can get one pretty reasonable here: Click here for formatter with network card built in
and Click Here for formatter without a built in network card
hope this helps and if so please mark this a FIXYA...
Jul 03, 2010 | HP LaserJet 4250n Printer
I bought a traveler 4gb sd card for my hp425 camera and it wont format.is there anywhere 2 reformat it online?
As long as you are running Windows 2000 Professional, Windows XP, or Windows Vista, you can use the SD Formatter 2.0 (from the official SD Association). You can download the formatter here:
http://www.sdcard.org/consumers/formatter/
The program is easy to install, and then when you're done using it, easy to uninstall.
May 21, 2010 | HP Photosmart M425 Digital Camera
No space, but memory stick is empty
If your talking about your sd card lets say 4gb now says something like 92kb free, like all your memory just disappeared, then try this program it worked for me.
SD Formatter
Procedure to Install of SD Formatter
1. Install the software after finishing the download
2. Close all running programs on your computer
3. Run or Execute the installer file
4. Follow the instructions in the installation window
SD Formatter Manual
May 17, 2008 | Electronics - Others
MEMORY CARD CORRUPTED
you should formatt the memory card...
go to menu
select the extra settings
open the memory card icon
and press options and select
formatt memory card....
and select yes..
and wait until it complete formatt.
and press ok..
Jan 06, 2008 | Nokia 6600
Nokia 5310 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
