Question about Turcom Tuco 10.2 Google Andoid 4.0 OS IPS Touch Screen Gsensor A10 Tablet Built-in Wifi, 16GB Flash Storage, Extend to 32GB Micro SD Card, 1080P HDMI Output, Support 2160P 16GB White
Reset default manual
Trying to reset to default
My trio stealth 10.1 won't turn on but when i put it on charger its stuck on android
Maybe do a soft reset. A soft reset does the task of resetting various internal adjustments to a default. It does not usually erase from memory your saved this-and-that.
You are on your own. Using the actual manual is your best advice. You can find manuals available for free online, usually from the device's manufacturer.
That's all I got.
A
Dec 03, 2016 | Tablets & eReaders
How do i reboot a fly touch v10 tablet
Tony, you mean reset, Right ?
Check the attached links, to see how to reset.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to do Manual Factory Data Reset on Superpad Tablets Android 4 0
How to reset the SuperPad Flytouch 2 Google Android OS 10 inch
How to Do Manual Factory Data Reset on Flytouch Tablet The Classroom...
Superpad VI How to reset to factory defaults FlyTouch 3 Superpad 2
Mar 08, 2016 | Tablets & eReaders
How to restore a amazon kindle ereader to factory settings
Try: Menu/Settings/Reset to factory defaults.
or Menu/Settings/Menu/Reset to factory defaults
Oct 02, 2015 | Amazon Tablets & eReaders
What wrong with a tablet when everything is backwards
Try a reset. There is a reset pinhole on most tablets to do this.
Check your manual if you have one or try to find one online.
You open a paperclip and put it into the reset hole and push gently. This will cause it to shut down and reset to factory default.
Something is wrong with your operating system to cause that.
You will lose any data or apps you might have saved.
Feb 21, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Loading issues please help xx
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Jan 05, 2015 | Android Gemini Tab
My tablet wont stay on i tried over and over
First try for a factory data reset.
if still the problem persists. it s an Hardware problem
contact authorised service center
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Mar 01, 2014 | Tablets & eReaders
I turned the talkback feature on and now im locked out of my tablet and i can't type in my pin code
Just make a factory data reset.
6)cheers your done.
Mar 01, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
How to reset Pandigital 7 in. Planet Tablet to factory settings?
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
Oct 17, 2011 | PANDIGITAL Digital Book 843967071153...
My Kindle will not wake. It is fully charged (green light), but the power switch does not clear the default screen.
try to reset leave your finger for few seconds at the reset power then remove and it will be reset the default
Jan 26, 2011 | Amazon Kindle 3G
Turcom Tuco 10.2 Google Andoid 4.0 OS IPS Touch Screen Gsensor A10 Tablet Built-in Wifi, 16GB Flash Storage, Extend to 32GB Micro SD Card, 1080P HDMI Output, Support 2160P 16GB White Logo
35 people viewed this question
Top Turcom Tablets & eReaders Experts
Are you a Turcom Tablet and eReader Expert? Answer questions, earn points and help others
