Question about GE 30000 Grain Water Softener GXSF30H
Water wont drain out of water softner
Water is not draining from tank
  • 262 Answers
SOURCE: washer wont drain
check the pump for socks or anything that dont belong but put your hand on it while its in spin/drain and see if pump is even running
Posted on Dec 21, 2007
VOTIT
  • 2071 Answers
SOURCE: water not draining
I encountered like this problem before,at bottom of your washing machine,there is a hole start tracing there until you reach the draining pipe out ,you find there many cloth fiber clogging up,when that clog is taken out already ,your washing machine will drain the water again,you can do it yourself, no need to call of a repair man..
Posted on Jul 12, 2008
  • 101 Answers
SOURCE: Softner won't drain
Sir,
if you mean that the softner (from the detergant drawer) will not enter the drum during the normal cycle, then....
the softner has become solid, you need get hot water and get the hardened softner loose within the pipe to the drum clear.
I suggest using a solid electrical cable core to clear it
Posted on Aug 04, 2008
  • 479 Answers
SOURCE: the water in the water tank in the dishwasher won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Posted on Dec 11, 2008
heatman101
  • 43501 Answers
SOURCE: water wont drain
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 15, 2010
Why is water sitting in the tank and how do we get it to drain so we can add salt?
the salt water is what removes the calcium and lime from the other tank containing the compound zeolite that does the actual softning of the water the salt tank should have water in it drain some out pour in salt
Oct 10, 2014 | Northstar North Star Water Softener , Flow...
Is there a city code for water softener recharge drain?
Well a lot of Cities and counties have there own ordinances for this. A good rule of thumb is not to discharge brine into sewer system or septic tank. Most drain into the yard. I have seen studies on different plants that actually thrive from brine water from softners. You may want to ant some of these and discharge that way. But to cover your self legally contact the City.
Jul 23, 2014 | Water Dispensing & Filtration
Softner wont drain
using wrong type of softner for these newer machines.
Feb 11, 2012 | LG Washing Machines
FABRIC SOFTNER DISPENSER NOT DRAINING
you can try putting a dishwashing tablet in it with some hot water and let it sit overnight ...the tablet has something in it made to desolve build up for water ,soap,ect...and it safe to the washer and to you too.I used one in my water drain on a water in the door ice box worked like a charm.
Dec 03, 2009 | Kenmore Washing Machines
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
My mark 812 water softener just lets the water run out into the drain cant stop it unless I shut the water off
sometimes the heads go bad on those and they get stuck in a regeneration cycle that just flushes the tank out. put it on bypass or call your softner maker and alot of times they will help you diagnose it and send you replacement parts. also some of the softner heads use small electric motors that get siezed as well
Aug 01, 2009 | Culligan Home
Fabric Softner not leaving dispenser
Run some vinger through it. Fabric Softner leaves a filmy residue that can clog it up.
Jan 11, 2009 | LG DLE5932W Electric Dryer
I have a whirlpool water softner. After regenerating, the water is still hard and the tank is about half full of water. I have cleaned the venturi.
Dec 06, 2008 | Whirlpool Dishwashers
Softner won't drain
Sir,
Aug 04, 2008 | GE WCVH6260F Front Load Washer
GE 30000 Grain Water Softener GXSF30H Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
