Question about Tablets & eReaders
Ampe a76 usb driver
Driver
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
I am asking if there is anything I can do to charge my Kindle...perhaps you can recommend the best car and electric chargers.
Hi Kathleen -
The Kindles I've seen all recharge off a standard USB type charger or from the USB port of a PC / Mac. The fastest charge will come from a 5VDC / 2.1 amp USB charge port on an AC (home) or DC (car) charger. There are some expensive types with "Quick Charge" or "Rapid Charge" technology that your Kindle will not be able to make use of - so skip those and save your money for the 5VDC / 2.1 amp USB types.
Oct 25, 2016 | Tablets & eReaders
Transferring from Nexus to computer
Hi I use a USB memory stick with female lead & mini USB male cable just download onto USB stick & plug it in you're computer good luck
Feb 28, 2016 | Google Nexus 7
Ineed a dc5vv2.0a that came with it I get other for it and do'not work and the usb is not work if did not come with the moblenab12-nv7a please help
If using the supplied / original BLACK and WHITE USB cord, the black must be used for charging. The white is for data transfer only and lacks connections for power / charging.
Most USB chargers will output 1 amp or less. Many USB jacks on computers output between .5 and 1 amp - max. Your device calls for a charger with 2 amps output. Connecting to devices such as those mentioned above can overload and damage the charger or computer - don't use them!
USB ports have standard connections or "pinouts". You should obtain a USB charger (5V DC) rated for 2 amps (or more for better performance). Be sure to select one with matching USB connector (compatible with your device) - mini, micro, etc.
Amazon has several from which to choose:
Amazon com nabi2 nv7a charger
Nov 12, 2015 | Nabi 2
What output volt and amp USB charger should I buy?
afunta.com
What does the manufactor recomend?
Jul 02, 2014 | Afunta
I need some drivers for i craig tablet usb cord driver
If you plan is to do Android Programming, you just need to download adb, or a rooting kit like RootThat. If you plan to just transfer files to it, BEFORE plugging in the USB connector, go to SETTINGS, scroll down to USB, and turn off "HOST MODE".
Now plug in; the tablet & the computer should recognize each other.
Mar 14, 2014 | Craig CMP741d Tablet
Usb wireless mouse driver works
The INF is the driver information file. It's missing the driver file. If I remember correctly, windows 95 does not support USB. I thought USB was first supported with Windows 98.
Dec 14, 2013 | Sharper Image Tablets & eReaders
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
"USB Device Not Recognized" - any usb device
It May just be a hardware problem... try putting in some new usb ports.
Dec 14, 2008 | HP Pavilion tx2120US Tablet PC
Tablets & eReaders Logo
19 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
