Question about Samsung RS2630WW Side by Side Refrigerator
I have a daewoo fridge freezer FR45065 N186 & the main door looks like it has dropped slightly & wont close , is it fixable thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
The door should be held on to the box by adjustable fixtures at top and bottom. One or both may have come loose. Look it over on the and bottom of the door. There is normally a cover over them that you will need to remove to access the mounting screws. Good luck.
Posted on Dec 30, 2013
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Hi, My fridge ( 420 ltrs)
The noise is the fan hitting ice build up on the coils... it is no defrosting properly...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 14, 2010
  • 12 Answers
SOURCE: Samsung Cool Tech Plus. Digital disply says -22 for freezer & +4 for fridge but freezer is thawing out & fridge not cold. All lights / seals etc are good. nno damage
turn off the fridge for two days, sounds like you have a drain blockage, causing ice to build up in your air channels
Posted on Nov 23, 2012
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Freezer seal
Good day,
The first step is to make sure the machine is leveled properly.
It should not be allowed to lean to the left. As well, the adjusters should be set, so there is a slight tilt to the rear, so the doors have a tendency to close on their own.
The freezer gasket should be cleaned, as well as the frame it makes contact with.
The reason this happens is a lot of air is pushed into the machine when the main door is closed. There are 2 openings between the main compartment and the freezer, so the air is forced into the freezer compartment, wanting to push it open.
If the gasket on the freezer fits well, then the problem, is the gasket's magnets have become weak.
The repair is replacing the gasket. However, many people find ways to use the machine by adjusting their habits to ensure the door closes. One example is to keep a hand on the freezer door when closing the main door, or, closing the fridge door slower.
In any case it's your decision as to what you want to do.
Feb 09, 2010 | Kenmore Refrigerators
My freezer door pops open when i shut the fridge door
make sure the fridge is tilted back a little so doors close with a little push by raising the front legs,also put some weight on the door, fill a bottle with water or any kind of heavy thing you want,this will hold the freezer door in place when you shut the fridge door
Dec 05, 2009 | Refrigerators
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Daewoo fr581 freezer not freezing
Behind fridge probably have a ventilator,check is it work,clean a gas cooler(radiator) from dust with a dry brush.If ventilator is not work change it.
Jul 04, 2009 | Refrigerators
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Samsung RS2630WW Side by Side Refrigerator Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
