Question about SanDisk Electronics - Others
My Sandisk SDHC Card Icon Cannot So any computer
    Champion:
  • 221 Answers
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
Posted on Dec 31, 2013
robmcd27
  • 423 Answers
SOURCE: Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Posted on Mar 03, 2009
SOURCE: SanDisk 8GB SDHC card cannot be read by either computer or T-Mobile Dash phone.
Solution :
Put the card in your phone, link the phone to your pc and format the card through your pc. You should see two additional drives, one for your phones memory and one for your card. I had the same problem with my phone but it is now sorted !
Paul
Posted on Oct 25, 2008
t00nz
  • 4738 Answers
SOURCE: sandisk sdhc card 4gb my camera says
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Apr 04, 2010
abdulkarimap
  • 149 Answers
SOURCE: sandisk ultra sdhc card won't record in my
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Posted on Oct 15, 2011
  • 15 Answers
SOURCE: i want recover my photos in my 4GB SDHC Sandisk Memory Card
Have you successfully restored all your photos back from this memory card yet?
If not, I think I can help you out.
Now, what you can do is really simple:
Step1. Stop using this memory card in case that any new file would rewrite your original photos.
Step2. Insert this memory card to your computer and prepare to restore your photos.
Step3. Download a photo recovery freeware to your computer and start to retrieve all your photos back:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera. So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/04/data-recovery.html
Step4. Save and back up all the restored photos on a different memory card or drive in case of data recovery failure.
Note: Next time, you'd better back up all your important photos on different memory cards or drives in case of the similar data recovery problems.
Posted on Oct 25, 2013
What program do I need to download my photos from my Sandisk Ultra 16gb SDHC Card
Is your card reader compatible with SDHC cards? While the card will fit into an SD-compatible card reader, it will not work unless the card reader was designed to be SDHC-compatible as well.
Nov 15, 2013 | Samsung SanDisk Ultra SDHC 16GB High...
My computer wont read my sdhc 4g sandisk card
Not all card readers, devices and computers can read the high capacity format, however. If you are getting a read error, it could be that your reader is not SDHC compliant. If this is the case, your device should read 2GB or smaller cards, but respond with an error for larger capacity cards.
Apr 24, 2012 | SanDisk 4GB microSDHC Memory Card
SanDisk 2GB microSD Memory Card not working
SaveMyUsb.com can recover data from most flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
I want to get rid of all the pictures on my SanDisk SDHC memory card. How can I do that?
Make sure it's not write protect enabled, insert it into the computer, and open "My Computer" (assuming you're using Windows previous to Vista).
Right click the drive icon that represents your SDHC, and click "format". If given any options, select "quick format" and click OK.
Within a minute or so, they're all gone.
If you want to keep ANY files on the card, and you just want to get rid of .jpg images, or whatever, you can perform a search on that drive for "*.jpg" exactly like that without the quotes. Once you've done that, it will find all those files, then you can right click and "select all", then right click again and "delete".
Aug 11, 2010 | SanDisk 2GB microSD Memory Card
Method for uploading computer pictures to sdhc card
simply highlight the files you want to send and then right click and choose "send to". select the drive letter of your sandisk
Aug 18, 2009 | Computers & Internet
Hi Tony,
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Sandisk 2gb micro sd card not responding
Too old of hard ware, SDHC secure digital hig compression, is preventing it from working. got to get a sd card that is not SDHC
Feb 23, 2009 | SanDisk 2GB microSD Memory Card
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Electronics - Others Logo
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
