Question about Giant Anthem X2
Creaking noise creaks from rear suspension
    Scholar:
  • 99 Answers
I know, this can be extremely frustrating...
First and easiest, check that your rear wheel is tightened completely, this can also sound like suspension noises.
Next, a bit more effort, unscrew your pedals, clean out the gunk, put some grease on the thread and replace, tighten securely.
You might also have to check your wheel bearings, mine is in the shop at the moment because of this, bearing issues...
I would also check the BB (bottom bearing) where your crank goes through, before the last step. This can also cause a lot of noise.
Lastly, if it is your suspension, you will have to take it apart, every link and check every bearing, they so have a limited life, clean out all dust and grit that gathered inside, replace and grease all bearings and links, but don't over tighten the links.
Here is a full service manual for you:
https://www.giant-bicycles.com/_upload_it/bikes/models/manual/Anthem%20Service%20Manual.pdf
For a full suspension service, you will have to look at every single point that hinges on your frame, I count at least five on one side.
Hope this helps.
Posted on Jan 11, 2015
Just bought a ford ba wagon and when you do a hard turn like driving in your driveway or turning in a street it makes a loud creaking noise coming for the front
check the strut or top strut bearing for failure
the creaking noise can be from the spring being wound up from turning as the bearing has seized
have it inspected by a specialist suspension shop
Nov 16, 2015 | Ford Cars & Trucks
Can up country shocks be used on a non-up country suspension. Worried about the travel and collapsed measurements. Not enough travel or too little?
doubtful the shocks would be the source of any creaking/squeaks. Most creaking and squeak noises are usually a result of worn/dry bushings. I would inspect all swaybar/control arm bushings for dryness and deteriation. Spraying wd40 on all rubber bushings in the rear may cause the noise to subside for a while until you are able to isolate the exactr source
Apr 30, 2015 | 2000 Jeep Grand Cherokee
Squeaking noise bump
High probability that it is the strut mounts, they don't have a very high life cycle. Very difficult to test while mounted.Creaking might just be a dry suspension, but the bumping noise definitely good indication of those strut mountings. You could check if fastening them more on the chassis makes any difference. Quick and accurate diagnosis if you can drop by suspension people.
Dec 18, 2017 | Jaguar Cars & Trucks
Ford ka creaking on drivers side when driving over bumps in road or turning
Is this a suspension creak, or a door creak?
Components which you haven't had changed are:
bottom suspension arms
Anti roll bar links
Also lubricate your door lock mechanism, hinges and window rubbers as these can cause creaks from time to time.
Nov 13, 2012 | Cars & Trucks
Creaking noise noise when taking off
Also possibly a slightly stuck brake caliper, or on a long shot, a CV joint. But the CV joint would be more likely if it was making noise when turning. Could also be a spring/strut/sway bar or other suspension component in need of lubrication, depending on how long the creaking lasts, etc.
Sep 10, 2012 | 2008 Volvo V50
Creaking noise coming from driver side rear drum after replacement
the brakes were not installed correctly or something broke hardware wise
Jun 06, 2012 | 2003 Toyota Celica
I have taken my 2003 GMC Envoy in to a GM dealer more than 6 times to be repaired for a very loud creaking noise in the front end. When I brake, the creaking noise starts. Or if I go over a bump, the...
My wife drives a 2003 GMC Envoy and has been complaining about this same creaking noise upon breaking or going over speed humps. I researched this topic on the internet high and low and tried everything I read to no avail. I was about to give up and then realized it could be the motor mounts since when you break or go over bumps the engine does have some movement. Sprayed the most interesting looking motor mounts I've ever seen with silicone spray and the noise was gone! My wife has been complaining for years about this noise and now looking back what a simple solution!. By the way my motor mounts where not worn out, the rubber portion of the mount just needed a little lube.
Dec 31, 2010 | 2003 GMC Envoy Xl
Rear End Creaking/Vibrating Noise on 99 1/2 VW Jetta GLS
Had a look on google looks like its on a subframe of sorts it could possibly be the rear subframe bushes or if its just been done garages use a lot ofcwd40 type stuff and that can cause the rubbers to creak untill it wares off best solution i can offer and thus might sound daft but get a bottle of cheap washing up liquid and squirt it over all the rubber joints this will desolve the wd40 and will wash away any grease ect it will come off by itself wgen it rains ifvtjis doesent work take it backbtobthe garage you gotvthe work dobe and tellbthem you problems hopevyhus helps cheers ivan
Jul 04, 2017 | 1999 Volkswagen Jetta
Creaking noise from front wheel
BALLJOINTS OR CVC JOINTS ?
Feb 12, 2009 | 1996 Audi Cabriolet
Giant Anthem X2 Logo
172 people viewed this question
Top Giant Cycling Experts
Andrew Taylor
Andrew Taylor
dante
 Russ Hill
Russ Hill
Are you a Giant Cycling Expert? Answer questions, earn points and help others
