Delay between sound and picture when on sky tv, is ok through airiel
All I want to register My Vizio, what is the big.deal I'm very upset
Posted on Dec 30, 2013
My goodmans ld2271d tv has no control. When I set it up with the sky box it comes on but no sound , even on full volume. can anybody help? Could it be stuck on mute?
check the sound setting on the sky box go to setting, then sound. audio out stereo
digital audio out optical (dolby D)
digital audio output hdmi (normal)
digital audio output delay (0ms)
this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
Oct 02, 2013 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have an lg ht805ph surround sound system attached to my SHY plus HD Box.Sometimes the sound is out of sync with the picture.How do I stop this happening?
the probable reason it is happening is the delay in your sky box decoding the signal and the surround sound decoding the audio. Have you tried taking the sound from the tv output and using that as the input for the surround sound and not taking it driectly from the sky box, which i am assuming your doing. If you turn off the LG and listen to the sound through the tv is it in sync, if its a random happening then it is the signal quality of the sky receiver thats at fault
Mar 10, 2011 | LG Televison & Video
Since retuning I have lost BBC 1,2,3,4 & Ceebeebees. I receive my transmission from Winter Hill, and have a Digifusion FRT 101 set top box connected to an Alba CTV3485SIL TV. I also use a Humax...
sounds like you need to rescan for channels, Should be in settings menu then maybe channels, Normally autoscan or channel update, Also make sure your airiel is good.
Nov 05, 2009 | Televison & Video
The screen appears blue after I switch the TV no rain or even a bad picture apear. seems to me that the tuner is completly faulty any idea?
What make? you dont give any usefull information.
My Phillips TV is blue if I have No Signal
Try inputing another signal from an aux input.
Check airiel is working with another TV
Oct 06, 2009 | Televison & Video
IVE BOUGHT A LOGIK AV SENDER AN THE PROB IS AFTER SETTING IT UP THROUGH MY SKY DIGITAL BOX TO MY TV UPSTAIRS I CAN ONLY HEAR THE SOUND AN CANT SEE THE PICTURE ALSO THEIR IS A WHITE, YELLOW AN RED LEAD AN...
ok these are called phono leads, yellow = video, red = left sound, white = right sound.
you need one of these http://www.maplin.co.uk/Module.aspx?ModuleNo=13372 there are 2 types, inputs and outputs, this one does both, (you need an output. sky to sender) let me know if this looks right for u
Jun 07, 2009 | Televison & Video
Problem with Lag between picture and sound
There should be a setting in the Home theater's menu (probably under Audio or Audio Setup) to increase or decrease the delay. Set this to the least possible delay, or if possible, no delay at all. This, from what I read is a very good unit so it should have this setting in the 'Menu', if you can't find it, the manufacturer should be able to help. Good Luck!
Dec 11, 2008 | Samsung HT-Q100 System
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Setting up 42lg3000 with sky and lg home cinema dvd system.picture and sound from dvd.poor picture and sound from tv speakers only from sky .please advise on correct wiring connections for this set up.TV...
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Nov 29, 2008 | Televison & Video
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Wife moaning at sound delay.......why.....
The sound delay would not be caused by hooking amp up but must be a software problem in sky box. Try to get an off air station with a antenna and see if the problem persists.The dvd recorder should see your sky box output first then out from recoder to tv.Then use tv audio out to amp,or tv audio out to amp. RANDY
Mar 16, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
