Question about Vizio SV470XVT 47 in. LCD TV
Vizio 47" sv470xvt1a 6" wide verticle green bar on screen
Happens after about an hour of play also have that hot plastic smell have had the tv since Jan
    Genius:
  • 1,139 Answers
Hello ,
I would suggest checking the driver circuitry for the LCD screen and I would also check the connectors from the driver board to the LCD. Either a component has begun to malfunction (hence the excessive heat) or the component has becom thermally sensitive and is reacting to existing heat and is allowwing excessive current to pass causing more heat to be generated. In any event have a qualified TV technician look at this problem because he will have the proper equipment to troubleshoot the TV in the proper fashion.
Posted on Jun 17, 2009
Vizio 46lfhdtv20a verticle rainbow line down the screen. picture start playing and after a while the color line cover the screen
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 29, 2016 | Vizio VO47L 47 in. LCD TV
2 yr old TV smells like hot plastic
Is it possible that the converter box is the source of the oder? Try unplugging it and run the TV.
Jan 24, 2015 | Vizio VO47L 47 in. LCD TV
Vertical Bars Horizontal Lines on LED TV
Check the input connections. If Ariel connection, or other video input connection from any external source have loose contact, or wire broken, this type of interference can occur to picture.
Gopakumar Gopalan Google
Apr 23, 2014 | Televison & Video
Fumes smell
Your Vizio TV is slowly but surely getting cooked. Whether to repair or replace is a decison you will have to make.
Jan 20, 2014 | Vizio Televison & Video
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
My Vizio SV470XVT1A, when turned on has vertical green lines, when playing a movie the lighter shades of color are good but all the dark shades have green vertical lines through them. I am trying to fidure...
All plasma an lcd TVs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They can sometimes be fixed, but it is a pain. An yes I have done it, and the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 03, 2010 | Vizio SV470XVT 47 in. LCD TV
Green shadows appear on new visio SV470VT. Very
It maybe a circuit control board for the screen. Last thing you want to do is void the warranty by opening up the TV.
Best to use the warranty at this point. Here's info to get you started.
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 28, 2009 | Vizio VO47L 47 in. LCD TV
Vizio SV470XVT1A makes screeching sound
This sounds as if it could be a ballast problem, or a switching power supply transformer problem. Both of these can produce this sound. I would suggest that you have a qualified TV technician repair this set due to the dangerous voltages and currents that could be present. In my experience with these TV I would have the technician pay special attention to the power supply board and the backlight/inverter section which includes the ballast used to fire the backlight.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio SV470XVT 47 in. LCD TV Logo
421 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
