Question about Philips HTS-6500/37 System
Philips HTS6510- Content cannot be displayed (Non HDCP Compliant)
My system has worked perfectly until now. Even when i don't put in a disc or usb after 10 seconds the screen goes fuzzy, if i change the channel to HDMI 2 then wait then put it back to HDMI 1 it comes back to normal then goes fuzzy after the same period of time. When you play a dvd by repeatedly changing channels when it gets to the menu screen of the film a blue box appears and says The content cannot be displayed as the device connected is non-HDCP compliant, Please Help
  • Joey77 Dec 11, 2007
    My system seems works fine now after a little play around with the cables i switched it off then unplugged and changed the HDMI cable and its worked fine so it must be the cable. Try this and it should work Captain !
Hi Joey,
This is the my second HTS6510. I sent the first one back in August as it would not play the disc nor eject it and I'd only just got it. The replacement has worked well until recently when virtually the same problem you are experiencing happened to mine without "the contents cannot be displayed" bit. It corrected itself but did the same thing tonight and this time it sometimes displays the "content cannot be displayed" bit. I think it is the HDMI out connection that is at fault. Could be that it cannot cope with the sound, but I'm a long way from knowing how these things work. If you come back on site and know the answer please share it with me. I will be getting onto the seller in the morning as it's still under manufacturers warranty.
Posted on Dec 11, 2007
  • captainBligh Dec 11, 2007
    Hi Joey,
    That's good to hear! This morning, I was about to call the seller and decided to have another try. Same thing happened, the blue screen and "no disc" came on and then the screen turned to fuzz. I left the player on and never touched the stand-by button which always removes the white light and puts the machine, as it should, into standby. Instead I used the tv remote and turned off the tv, at the same time it caused the player to go into standby. I then turned on the tv again, pressed the on button of the player, did the usual with the AV on the tv's remote and Bob's your uncle the screen displayed the usual blue screenl and never went into fuzz-mode. I inserted a dvd and it's back in business. Glad I never called the seller as a visit from the repair man, here in the UK, would have been costly if it was just a matter of using the controls properly. Anyway glad we are sorted. Have a Happy Christmas and don't watch too many movies, your eyes will go square. Actually the HTS6510, for the money £240.00 (or $480) is quite a delight to watch movies on but I might get myself something a bit more pricey next time.
  • nickabyrd Oct 25, 2010
    Your problem is a product of HDMI technology, not the player itself. When HDMI cables are plugged into powered equipment, any loose dust can be attracted to the cord or port (like during the initially plug-in or during trouble shooting). This causes interruptions in video and audio. The dust can even interrupt signal entirely, which might cause a 'no signal' warning or a 'Not HD compliant' signal.
    To resolve this issue, unplug TV and DVD player. Then, unplug the HDMI cable to both, wait ten seconds. Replug HDMI, wait ten seconds. Unplug HDMI, wait ten seconds. Replug HDMI, wait ten seconds. Then plug the power in to the TV and DVD player again. It should work. This troubleshooting technique is called 'hot plugging.' Almost any upconverting DVD player might require it.
What does 'this tv dose not support this programs content. Replace HDMI with component cables to view' mean?
The message has appeared because the TV can not display the hdcp signal that is now used to enable copy protection over the HDMI cable due to the TV being older than the hdcp encryption system (the hdcp is not fitted to your TV )
The two options open to you are
Replace the TV with a hdcp compliant TV
Get a component lead set up
Apr 01, 2016 | Sylvania Televison & Video
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
I have a Samsung C230 LED monitor and I'm wondering if I can use it with a Roku XD/S in place of a TV via the hdmi cable?
as far as i can tell this monitor is not HDCP compliant ( High Def Copy Protection ) and therefore will not be suitable as a TV monitor. Computers can use non HDCP compliant monitors but TV Tuners, Satellite Receivers, DVD players etc with HDMI are HDCP compliant and must have a HDCP display... HDMI has two formats basically HDCP and non HDCP
Sep 04, 2013 | Samsung Syncmaster 940BW LCD Monitor
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
Hdcp error mesage when connected to my freeview hd box.
What is a HDCP error? Here is a real life situation that happened that could happen to you. You just bought a Blu-ray Disc Player and connected it to your older HDTV with a HDMI cable. When you tried playing a Blu-ray disc a HDCP error was shown on the screen. The movie wouldn't play.
This is a known issue with HDCP, and it's one of the biggest hassles consumers will have to deal with when utilizing a HDMI cable on their HDTV. You will get a HDCP error if you try watching HDCP encoded content when using a HDMI cable.
The problem is that if HDCP exists anywhere in the video stream then all devices and cables accessing this content must be HDCP compliant. If one device or cable isn't HDCP compliant then you get a HDCP error.
The only solution is to either replace the HDMI cable with a non-digital cable or replace the HDCP-less device. This could mean buying a new HDTV. In fact, I worked with a reader last year troubleshooting a HDCP error on his TV. What happened is that he bought a Blu-ray Disc Player and connected everything properly only to get a HDCP error. After a few emails back and forth we discovered that his HDTV wasn't HDCP compatible, which is why he got the HDCP error.
The reader ended up buying a newer HDTV with HDCP, and his Blu-ray Disc Player worked perfectly with HDMI cables.
Nov 22, 2010 | Televison & Video
I cannot view HD channels (from freeview HD box) through my Sony str-dh810. I've narrowed the problem down to something called HDCP. When HDCP is on, I cannot view anything from my freeview box. Turning...
This piece of information should solve your problem:
High-bandwidth Digital Content Protection (HDCP) is a form of Digital Rights Management (DRM).
There is a licensing body that issues licenses for HDCP devices. Each HDCP-compliant device, like your Blu-ray player or Xbox, has a license and the ability to talk to the receiving device on the other end of the HDMI cable. The outputting device says "Hey display! Are you HDCP compliant? Here is my license, show me your license!" The display (or other HDCP compliant device) returns with "Why yes, I am legit! Here is my license!" When that process works, it happens within a thousandth of a second and you, the consumer, never even notice. You power on your Blu-ray player or DVR, it makes nice with your HDTV, and you live a happy life never knowing what HDCP even is.
if you have an older HDTV set that is not HDCP compliant then you cannot watch any HDCP compliant content on it. If you plug in your HDCP-compliant device to a non-compliant device, you'll either see a blank screen or an error message like "ERROR: NON-HDCP OUTPUT," "HDCP unauthorised," or simply "HDCP ERROR."
Short of buying a new television or giving up on your video game project the only way to deal with your HDCP compliance problem is to buy a cheap HDMI splitter that ignores HDCP requests.
Sep 25, 2017 | Sony STRDH810
Panasonic PT-AE2000U All three HDMI Ports stoped working. I have tried different HDMI cable and a three different HDMI Feeds. I can get a picture using the red green blue component cable. Any ideas?
WOW. I just experienced the same thing. None of my HDMI ports are working, though component is fine. I've had my unit since November 2007 and had no problems until this. I think the HDMI board has gone bad and will require replacing.
May 20, 2010 | Panasonic PT-AE2000U Projector
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Non-HDCP Compliant Error
Jan 06, 2008 | Protron PLTV-32 Television
Philips HTS-6500/37 System Logo
1,210 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
