We have a subzero 650. IT is making a loud noise, hear it most when you pull open freezer door. When you pull the door completely out, it stops. It sounds like a fan or motor. When you push the freezer back in, it starts up again. Probably need a repairman to come look?
Yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
clean the coil up top and if that does not help ck the air valve / in freezer it's fluttering and may be sticking .. yu can use a spray silcone on it .. mm
