Question about Toshiba SBX4250 - Powered Soundbar and Subwoofer
Sound sincronisation between TV and speaker
Slight delay between sound and lip movement
I need code to unlock my dc 2000 pvr recievr
Posted on Jan 01, 2014
Lip sync problems
that is a network problem nothing consumer can do about it .
Sep 29, 2015 | Televison & Video
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
Lip Sink issue, when playing a DVD Lips move & seconds later sound comes out.
Hello your center voice delay is set too high..Go into the audio menu(viewable on the tv) and reset the delay to 0 milliseconds.
Feb 21, 2011 | LG LHT854 Theater System
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
I have a Yamaha RX V800 AV Receiver is their an lip sync adjustment for internally with this amp.
This monster has a lot of built-in opportunities to tune or mis-tune the sound but nothing to deal with the effect you're addressing.
A discussion of lip sync:
http://en.wikipedia.org/wiki/Audio_to_video_synchronization
  • There is extensive use of audio and video signal processing circuitry with significant delays in television systems. Particular video signal processing circuitry which is widely used and contributes significant video delays include frame synchronizers, digital video effects processors, video noise reduction, format converters and MPEG pre-preprocessing.
  • The video monitor processing circuit may delay the video stream. Pixelated displays require video format conversion and deinterlace processing which can add one or more frames of video delay.
  • A video monitor with built-in speakers or line-out may not delay sound and video paths by the same amount of milliseconds. Some video monitors contain internal user-adjustable audio delays to aid in correction of errors.
  • Dec 31, 2010 | Yamaha RX-V800 Receiver
    Haveing trouble syncing the sound with lips is there a trick to do this? also whats the best setting to get the best true surround sound by the way i have Rx-v465 with klipsch 300 home theater speakers.
    RX-V465 has auto-sync feature over HDMI. So if you have your DVD and TV connected over HDMI, receiver will communicate with your TV and set the delay automatically based on TV processing speed.
    You can turn auto-sync on in Setup menu / Sound Setup / Lipsync / HDMI Auto.
    Or if that doesn't work for you, you can set a value in milliseconds manually in the same submenu.
    Jan 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
    Sound doesnt sync up from direct tv to the speakers
    hi, are you trying to get sound from your TV through your home sound system? I'm not quite sure what you mean about "direct TV" thing if that is a specific term. Please ellaborate.
    If you have a line (audio) output on your TV then it could be easily connected to an auxillary line input in your sound system controller. hope this helps..
    Oct 23, 2008 | LG LHT854 Theater System
    HDtv picture and av reciever sound do not match
    I have a hdtv hooked up with a virgin v+ box but slight delay Why?
    Dec 06, 2007 | Televison & Video
    Sound/Video delay
    Lip-sync error is a widespread problem caused when video is delayed and audio arrives too soon. Widespread enough that three different manufacturers make dedicated products to address it, in fact (see review link below for those three). It is present to some extent in essentially all broadcasts and DVD?s. If you have a recently acquired DLP, LCD or plasma display it may have added enough additional video delay to make it noticeable but lip-sync error comes from MANY sources starting at image capture and continuing through post production and broadcast or DVD encoding and it is cumulative. There is usually enough lip-sync error in broadcasts and DVD's to cause a negative impact on viewer perception (Research done at Stanford showed this.) Many people don't consciously notice it until it gets very large because it's such an unnatural phenomenon ( audio can't come before the action causing the sound in the real world) we apparently subconsciously avoid looking at the faces and seeing the lips move "after" the sound from them is heard. A study at Stanford proved this causes negative viewer perception even for those who don't notice it so this is something we all need to notice as you already have. For those reading this who haven't noticed it, take a close look at the LIPS - force yourself to overcome your natural avoidance mechanism that keeps you from looking at the lips - and you will see lip-sync error you never noticed before. I think you will be amazed that you could possibly not have noticed it before. You will be seeing what JC is seeing. I even see it now on CRT TV's and am amazed I never noticed it so it's very obvious some avoidance mechanism is at work. And back to JC?s solution: I'd recommend one of these digital audio delay units. That way you can correct for ALL cumulative lip-sync error no matter what its source might be. Any one of these units reviewed will correct it ALL. With any one of these units you can adjust for perfect lip-sync at the start of each DVD or broadcast and not disturb the image you are watching during that fine adjustment. I have had a Felston DD340 since 2004 (three generations earlier than the DD740 covered in the review) but it still has the most important feature of all these units from these three different manufacturers which is their "plus and minus" buttons on their remotes that allow you to tweak the delay while watching your material without upsetting the video your are watching. My av receiver has a built in delay of 80 ms which isn't even enough audio delay to offset the video delay my plasma display adds but even if it were it isn't practical to adjust it for the changes in lip-sync error from program to program and DVD to DVD since it overlays the screen with menus when making the delay adjustment. With my DD340 (and any of the units reviewed) all you have to do is press the plus or minus button until you get perfect sync. Here is the review I mentioned: [URL="http://www.audaud.com/article.php?ArticleID=3011"]
    Aug 30, 2007 | Audio Players & Recorders
    Sounds don't align with lip movement
    if you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
    Jun 15, 2007 | Westinghouse SK-26H240S Television
    Toshiba SBX4250 - Powered Soundbar and Subwoofer Logo
    55 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
