Connection of chord adopter
Conection of adoptor cable
    Champion:
  • 232 Answers
Is it a problem with the charger itself or the port on the laptop where you connect the charger? Please clarify your question for us.
Posted on Jan 05, 2014
2 Suggested Answers
vithob
  • 100 Answers
SOURCE: Sony vaio Adopter is beeps when i connect to power supply
I think ur adapter have some problem.Better to change ur laptop adapter and check it.whether it give same problem.Then please contact nearest service center.
Thanks
Posted on Feb 27, 2008
I have an epilator (Remington Model # EP-6025). I have been using it in US and now, I would like to use it in India. Can I just use an adoptor for the chord and use this epilator
Yes, India uses 230 Volts at 50 Hz alternating current as the power source. Plugs and sockets have either grounded earthed 3 Pin connections (Type D) or ungrounded 2 pin connections (Type C).
All you need is an adaptor like the one in the picture.
Dec 27, 2014 | Remington Ep6025 Epilator
Cant get conected
Can you clarify the problem? I have the same modem. make sure that the coax cable is connected to your wall and that the ethernet cable is going from your modem to your router or computer. If all else fails pull the power chord out of the back (thin black chord) and wait 30 seconds or so, and plug it back in. This will reset your modem.
Sean
Apr 01, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Hi am franklin i wanted to ask that every time i try to conect my samsung champ to my pc throuhg usb chord through samsung pc studio for internet conection . but samsung pc studio...
you have to uninstall your pc studio .  then download new pc studio ( you can download from here ---
"http://in.samsungmobile.com/support/softwaremanuals/newPCStudio.do" ) .
and install it .
then it will definitely work ( unless your data cable is damaged )
Dec 31, 2010 | Samsung Lands Phones
I put the usb wireless adopter and mouse don't move
Good day!Try removing the mouse cable and plug-it again..or remove your USB adoptor a while, see if its functioning..and plug it again..
regards..
mastergani
Mar 26, 2010 | Belkin Mini Wireless Optical Mouse...
Every time i connect my av. chord it gives me the e74 but when its just the pwer chord it works ive bought a new av chord it has the same thing showing up
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Feb 18, 2010 | Microsoft Xbox 360 Console
My built in wifi HP Wireless Assistant is not available. Ineed to install it again. It is a wireless network adoptor to connect internet via wifi
Boss You need to install suitable wireless network adopter so as to support your wifi in the laptop. generally the most common Network adopter used in Hp laptops is Atheros AR 5006X.. so go the device manager of the lapltop and check it out whether the drivers are working fine or not.. so install New drivers if required.. which you can easily find in internet.. some of the common website are..brothersoft.com..etc Hope that helps you.. Regards Gizokieth
Oct 06, 2009 | HP Pavilion dv6000z Notebook
I can't get my e machine to find any network from my 2 wire wireless router
Your machine is not installed with Wireless adopter. Install a Wireless Lan adoptor. so only you can be able to discover the wireless router. Kindly give feedback.
Aug 23, 2009 | E-Machines eMachines Desktop PC
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
Thanks
Feb 26, 2008 | Sony VAIO VGN-N130G/W Notebook
Power adopter of microtek scanmaker 3840
any kind of adoptor with 12volts output 50/60hz will do...
Jan 03, 2008 | Microtek scanmaker 3840
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
