Question about Toshiba e-Studio 350 Copier
Crc error f104 - Toshiba e-Studio 350 Copier
  • 45 Answers
Problems with the hard drive, try the 08-690
if it does not replace hard disk and load the firmware
Posted on Dec 31, 2013
Error code F104
F104 is logic board (main board) MUX failure.
Action:
1) Recycle power to the cooktop.
2) If problem continues, replace logic board (~$250 part)
You can read my other entry as to how to open the unit. It seems strange that the board would fail simply from moving. That is assuming that it was properly reconnected electrically to an appropriate circuit. It is certainly worth opening up the unit and simply checking all cable connections to the board and looking for any visible damage (not that there will always be some for a failed board) before paying for a replacement.
I should point out that GE's troubleshooting instructions often end quite quickly in logic board replacement. Either they anticipate a lot of failure of these boards or they like selling replacements whether necessary or not.
Nov 02, 2012 | GE 30 in. Profile JP939 Electric Cooktop
My toshiba e-350 displays F104
F104 indicates HDD CRC error.
What u can do:
Perform bad sector scan 08-694. If result fail, u might need to replace HDD.
Jun 07, 2012 | Toshiba e-Studio 350 Copier
I have a Bosch Exxcel showing error code F104. What does this mean
This code typically means that the pump is blocked. You should get a reputable engineer to come out and unblock it.
Feb 28, 2011 | Bosch Washing Machines
After shutting down the computer a few times when transfer file from PC to CAXE3702T0, all of a sudden, blue screen and when the Window 7 boot up again, it said the CAXE3702T0 has CRC problem. I tried...
CRC or Cyclic Redundancy Check is a process that helps in identifying any errors that might occur during the data transmission process. Data is usually transmitted in small blocks, and a CRC value is assigned to each block and transmitted along with it. This CRC value is verified at the destination to ensure that it matches the CRC value transmitted from the source. A CRC error occurs when the two values (source and destination) do not match and the test fails. The main benefit of CRC is that it helps you ensure that data you have received or downloaded is not damaged or corrupt.
Causes of CRC Errors
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Jan 14, 2011 | Cavalry Storage (CAXE3702T0) USB Hard...
DMA driver error CRC error G sonyDVD RW AD 72605
Resolving CRC Errors
Let's now have a look at the methods you can use to resolve some of the common CRC errors on your Windows system.
Fixing Transmission Problems with Network and Modem
You may encounter CRC errors while trying to transmit files over a network or a modem connection if there are problems with the connection you are using or there are data collisions occurring during the transmission due to heavy traffic.
Additionally, you may receive CRC errors if you are not transmitting your file in a format that is compatible with the protocol being used for transmission. For instance, if you are sending a text file through an FTP or Telnet session, it must be sent in Text mode or as an ASCII file. Non-text files, however, must be transmitted as binary files.
To resolve these problems, you can try the following:
  • Ensure that there are no problems with your network or modem connection.
  • Try to retransmit the file.
  • Try sending the file using some other method or connection.
  • Ensure that the file was sent using the correct format.
Dec 06, 2010 | Sony (CRX320AE/U) CD-RW/DVD-ROM (Combo)...
When i try to install the sims 3 File: E:/Chaches/Sunset Valley.objectChache Error: Data error (cyclic redundancy check). pops up i cleaned the disc but it didnt help
If 'E:' is your CD/DVD drive, then some of the data could not be _correctly_ read from the disk.
When the data was written, a CRC value was calculated for the data, and that CRC-value was written onto the disk immediately after the data. When the data is read from the disk, the CRC-value also is read from the disk. A "new" CRC-value is calculated from the data that was read, and the "new" CRC-value is checked against the "old" CRC-value. If the two values do not match, then the data retrieved does *NOT* match the data that was written, i.e., you have an "I/O error".
Take the defective CD-ROM back to the retailer, and get it replaced, under warranty.
Nov 21, 2010 | Computers & Internet
I have an crc error problem when i install any game likh fifacricket they give me a crc error plzz givem e solution to solve this problem
CRC error usually indicates a problem with the hard drive. I suggest you do a full scan of your hard drive and have it mark all the bad clusters.
thanks adi
Jun 22, 2010 | Computers & Internet
CRC Errors
change your CRC bios battery.
May 25, 2009 | MSI KT4V (MS-6712) Motherboard
CRC error??
"In simple terms, a CRC (cyclic redundancy checks) is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted."
so, yes, the CRC error is most likly the problem.
May 07, 2008 | Computers & Internet
Toshiba e-Studio 350 Copier Logo
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
