Question about Haier Energy Star ESA3183 Air Conditioner
Ager unit don't know how old it shows F4 code and no cold air
Please , may i know f4 error code in split type air conditioner
Here is error code f4
light fan motor of indoor
1?Check whether the contact of the plug of the motor wire 8 unit fault and socket is well, making sure well contact.
2?Check whether the indoor motor has damaged, the motor should be replaced when it is damaged.
3?Check whether the controllable silicon and other components on the electric control board have damaged, replace the controllable silicon or electric control board when they are damaged.
click on the link below and scroll down the left side to find error code f4...CHEERS
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Mar 20, 2016 | Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
F1 08 f2 08 f3 08 f4 08 error codes vulcan comfort control what does it mean
What sort of machine is it? Refrigerated, Ducted, Gas? To do a full reset correctly, you must switch off at the main isolator next to the unit or at the meter box and leave it off for at least 15 minutes. A quick on / off does not reset it properly. If the unit is a refrigerated split system , and the outdoor is running but the machine is not blowing cold outside and hot inside (On heating mode) It could be due to a gas leak / shortage.
May 26, 2015 | Heating & Cooling
Air Conditioner Error code?
Error "FL" is coming It is not going by applying suggesstion in your booklet kindly enlighten
Mar 16, 2009 | Haier Energy Star ESA3183 Air Conditioner
Idle raises to 2500 rpm when car is very hot
Check the inlet air temp sensor. It should be located near the airbox but before the throttle body. This unit does not show in code. It registors the outside air temp and adjusts throttle and fuel mixture to match. If the sensor id faulty it will show as being cold and set the throttle for cold starting and running. Check manual or Autozone for multimeter ohms check on this unit.
don
Sep 30, 2008 | 2003 Ford ZX2
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Haier Energy Star ESA3183 Air Conditioner Logo
27 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
