Question about Golf
Aim headlights on yamaha drive golf cart
How to aim headlights on yamaha g28
4 Suggested Answers
  • 82 Answers
SOURCE: How do I disconnect the back up beeper on a 2003
There is a wire connected to the back of the shift lever (inside engine compartment), disconnect it and wrap it in electrical tape (so you can re-attach it again later)
Posted on Apr 30, 2009
  • 21 Answers
SOURCE: Yamaha 4 stroke golf cart back fires all the
Very important... valves get out of adjustment and are easy to set. This is where I would start FOR SURE. Check out www.buggiesgonewild.com and an example of how to do it on EZ GO 295 http://www.buggiesgonewild.com/ezgo-gas-tech/1196-ezgo-295-350-engine-valve-adjustment.html
Posted on Jul 20, 2010
  • 3567 Answers
SOURCE: i have a 1980's yamaha golf cart and it keeps
If you are saying that the motor keeps on running after the key is turned off, one of three possibilities exist. The key switch ihas gone bad, check it with an Olmmeter. Someone has messed with the wire connections, check out all wiring for proper color coded connections. The engine is deiseling because of carbon buildup on the piston and cylinder head. This is the most likely reason for the continued running. The carbon buildup will create hotspots that are hot enough to ignite the fuel even without the spark plug. Pull the head and scrape the carbon off using a screwdriver and a wire brush. Also, clean away any dirt, leaves, grass clippings or whatever may be blocking air from cooling the engine. The starter solinoid can go bad but you surely know the sound of the starter motor verses the sound of the engine.
Posted on Aug 19, 2010
2008 Yamaha golf cart what drive does it have
It is either gas and has a gas tank or it is electric and has 4 x 12 volt batteries. Search Results
Owners Manual Download - Yamaha Golf Car
https://www.yamahagolfcar.com/ownersmanualdownload/ You can find them on the Yamaha Golf Car Owner's Manual section of the site. ... If you have a service related question, please contact your authorized Yamaha ...
Find Your Model/Serial Number - Yamaha Golf Car
https://www.yamahagolfcar.com/findyourmodel/
This overview page connects you with the resources of Yamaha Golf Cars dedicated to keeping your ... Follow the steps below to get information on services.
What Year & Model Is My Yamaha Golf Cart? ' GolfCartGarage.com
https://www.golfcartgarage.com/what-year-is-my-yamaha-golf-cart/
This guide will help you determine the year and model of your Yamaha golf cart. ... If the serial number begins with "JW9-300101" you have a 2013 Yamaha DRIVE. ... 2008. JW2-000101. YDREE. 2007. YDREPT (The DRIVE PTV). Beginning ...
Yamaha DRIVE Gas - Specs and Features - Golf Carts and NEVs
golf-carts.axlegeeks.com/l/7/Yamaha-DRIVE-Gas
The DRIVE by Yamaha is a gas powered specialty vehicle that can hold at most two ... The cart has a peak power output of 11.4 horsepower, 0% more than the ...
Yamaha G14 Golf Cart Specs ' Yamaha Year & Model Guide ...
www.performancepluscarts.com/yamaha-year-guide/
Need golf cart parts for your Yamaha golf cart, but don't know the year or model? Visit our website to ... Yamaha Serial Numbers will indicate the year of production. View the .... The Yamaha Drive is the newest addition the the Yamaha Golf Car line and began production in 2007. ... JW1-100101 = 2008 JW2-100101 = 2008.
2008 Yamaha golf cart what drive does it have Google Search
Mar 22, 2017 | Golf
What type of oil does the yamaha golf buggy use ?
Mike, Yamalube 4-cycle oil or quality SAE 10w-30 motor oil, is the oil for use in your cart. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
what kind of oil 2 use
What Type Oil and Amount is used in Yamaha G22 Max Gas Golf Cart
What type of oil does Yamaha golf cart take
Aug 07, 2016 | Golf
Where is the fuse for the headlights located on a 2009 Yamaha electric golf cart?
Go on BING images. Put in Yamaha Golf Cart diagram, and all sorts of info pops up.
Nov 15, 2014 | Motorcycles
Yamaha Golf Cart won't start
did you leave the key on and kill the battery or a light or something double ck that battery , they will still light up the ignition and lights and ll but does not have enough to crank the starter , that is what is sounds like to me be put a jump on it or charge it and try again , when you turn on the ignition does the lights light up on the dash panal if so the batter is low
Mar 26, 2014 | Yamaha G-20 G20-g22 G-22 Golf Cart Tune Up...
We have a Yamaha 2009 golf cart that bounces. We have a speed chip put in the cart and it started bounce. We've checked and replaced the tires. The mechanic at the golf cart dealer can't fi
Replace the chip with the original one and see if the problem is still there, If it isn't then the problem is with the chip, perhaps the golf cart is going faster now and the suspension cannot dampen as efficiently?
Dec 22, 2012 | The Drive 2008 Golf Car Sandstone Metallic...
Golf Logo
185 people viewed this question
Top Golf Experts
Ronald Prier
Bill Boyd
Tom Chichester
Are you a Golf Expert? Answer questions, earn points and help others
