Question about Jet 3 Ultra Power Chair
Why won't chair move?
Battery indicator lights flashes continually but chair, but chair will not move.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Check levers under chair make sure they are engaged,first
then turn off power and reboot
Posted on Jan 19, 2014
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
  • 8 Answers
SOURCE: All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
Posted on Jun 11, 2009
  • 103 Answers
SOURCE: red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
Posted on Jul 23, 2009
  • 175 Answers
SOURCE: The chair suddenly lost power and now the lights
If he put in the batteries (2) properly, they should never sizzle. Some will emit a very minute spark when the final connection is made, but that is normal. There are fuses coming off of each battery to the power controller that will blow at 40 to 100 amps or so, depending on the chair; these will blow before the chair frying, or the circuit breaker will trip, or the controller will fry and all will be quiet on the chair, so I am going to say that the batteries weren't properly hooked up, otherwise on of the above items would have shut everything down. Continuous flashes indicate trying to start the chair while it is still on the charger, or with the joystick off-center. Make sure it is unplugged and notohing is resting against the joystick. If it's still a no-go, then you have either a joystick issue or controller issue. You will need to test those by replacing with known good controller/joystick, which a dealer should be able to do for you. Good luck.
Posted on Jul 24, 2009
SOURCE: pride mobility Jet 3 Ultra
Hi, well as long as it's operating Ok, then we are all good,and perhaps it is something simple, such as there is NO profile, or a Profile hasn't been set, or chosen?
www.pridemobility.com/pdf/...Manuals/US.../US_Jet_3_ultra_om.pdf
above & below, are your manual so you can check settings etc.
www.pridemobility.com/...Manuals/product_owners_manuals.asp
Below is your troubleshooting website How To.
www.pridemobility.com/.../basic_troubleshooting_guides.asp
Posted on Mar 29, 2011
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jul 16, 2014 | Jet 3 Ultra Power Chair
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Battery level indicator continually flashes when turned on, chair does not move.
Not much info to go on, but you may be in Lock Mode. On a VSI the Profile LEDs scroll left to right.To Unlock a VSI: Push joystick forward until beep, then pull joystick back until beep. Unit is now unlocked.
Mar 09, 2013 | Health & Beauty
Powerchair doesn't move 1 red light blick's on the leftside of VSI
John,
This flash code indicates that the battery needs charging or there is a bad connection to the battery. Check the connections to the battery. If the connections are good, try charging the battery.
This flash code can be seen at the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
With the battery voltage too low the chair will not move. Hope this helps.
Jan 08, 2011 | Jet 7 Portable Power Chair
I charged up the battery for my Auto go 550 mobility scooter over night the next day I went to use it and it wouldn't go. The battery light was flashing but it was only flashing on the red, amber ,and...
My AUTOAGO power chair was loaned to a friend that ran a daycare. She parked it for month between foot surgeries. One of her children likely moved the transmission lever to neutral. So even with fresh batteries all the lights on the battery indicator were flashing. I took to a shop and they showed me the lever. All is well now.
Nov 01, 2010 | Health & Beauty
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Sep 08, 2010 | Jet 3 Ultra Power Chair
Flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
Jul 23, 2010 | Quickie Wheelchairs Quickie Aspire Power...
Chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jet 3 Ultra Power Chair Logo
133 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
