Question about Refrigerators
Subzero 611 freezer not cooling
I noticed that the temp in the bottom freezer section of my Subzero 611/F manufactured Dec 1999 was slowly creeping up a few days ago. (The upper fridge section is working fine.) The vacuum condenser message was also displayed. The fan in the freezer section was running fine, and there was no ice build-up that I could see. I opened up the grill to check things out. The condenser was almost completely dust free, but was quite warm, and the freezer compressor was almost too hot to touch (this unit has separate freezer and fridge section compressors.) I did notice that the condenser fan was not running continuously. It would start when I gave it a push, but then stop again after a while. I figured I had a faulty fan motor. I shut off the unit at the outlet, emptied both sections and let it sit overnight to cool the condenser/compressors down and let any ice build-up melt. I then vacuumed out what little dust there was in the condenser and around the compressors, and turned the unit back on, with a pedestal fan blowing directly onto the condenser/compressors. After about 6 hours the temp in the fridge section was back down to 34F, but the freezer section has bottomed out at 41/42F and hasn't moved in a couple of hours. Funnily enough, the condenser fan has now been happily running all this time as well. The condenser is nice and cool, but the freezer compressor is hot (though not as hot as it was before.) So, now I'm puzzled. Why is the freezer not coming down to proper temp with the two fans blowing? Is the condenser faulty?
  • Mark Dietrich
    Mark Dietrich Dec 31, 2013
    After further research, I think my problem is more likely to be compressor/freon related. While the coil going into the condenser for the fridge section is warm (as it should be), the coil going into the condenser from the freezer section is not. This seems to indicate that heat is not being drawn out of the freezer. The evaporator is really cold though (as it should be), so it seems that I've got cold going into the freezer, but no heat being drawn out. Does this indicate I am low on freon (and therefore a leak somewhere)?
    Master:
  • 966 Answers
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Posted on Dec 30, 2013
3 Suggested Answers
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
  • 157 Answers
SOURCE: Refereigerator Model GBE18JBRWW, bottom freezer Not
You have a defrost system problem. The coils with the ice are the evaporator. If the fan is working inside either your defrost timer or defrost heater assembly has failed. you may want a tech for this
Posted on Jun 22, 2011
Recently moved into a new apartment that has a Subzero 611 Just put in 4 new light bulbs and none of them are working
try the light switch. located in the upper part of the fridge or freezer. is the white switch. the black an white is for the fan. REALLY EASY
Jan 30, 2010 | Sub-Zero 611 / O Bottom Freezer...
Subzero does not cool sufficiently, even with cool
yes you have 2 compressor. ona for fridge one for the freezer..
Nov 29, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero not keeping cold. It will cycle on and cool properly, then after a while the temp goes up to near 50 and it takes too long to cycle on to cool down again.
Call a subzero repairman. My subzero had a leak in the refrigerant coolant tubing. Trust me, only a trained and equipped repairman has a prayer of fixing this.
Mar 16, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
Sub-Zero 611/O not cooling
sorry but i do not have experience with hte sub-zero product line, I can reccomend to you thought that it is a very expensive piecce, and replacing it ( with another sub-zero) may prove to be a more costly option then the repair, Generally a Qualified subzeroe technician, (at least inmy area) is strictly a SubZero, specialist, so although you may pay a premium for the service it will be backed by the manufacture, and only 6-7 years old i cant imagine a problem that would justify replacing the unit.Althougth Im a Do-it-your self advocate, there are somethings that are generally best to leave to a professional opinion. This would be my reccomendation
Jan 17, 2009 | Sub-Zero 611 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
