Question about Ricoh FT5832 Copier
Produce a dirty copies
The copier produce a dirty copies, how can we make clean copies?
Peter
  • 469 Answers
Sound like the machine needs a service, The Optics should be cleaned, and adjusted, machine cavity vacuumed out, rollers and belts cleaned, paper feed and fuser rollers inspected. drum and developer checked. Etc, Etc. Once this is done, the copies should be as good as new.
If you need more information, please contact us.
Hope this is of some help.
Ed
Posted on May 19, 2009
My copier kyocera fs 9530dn is producing faint copies.What can i do to rectify the problem
clean the main charge corona. hope you haven't been using cheap non kyocera toner or you likey sucked all the developer out of the dv unit. in that case a full maintenance kit would be the best answer. could also be ozone haze on the mirrors or a dirty laser unit
Oct 28, 2015 | Kyocera Office Equipment & Supplies
How to fix dirty copy in np7250
You better upload an image, because there are many kinds of "dirty copy". Also you'll need to check the counters to see if is not the time to replace Developer Unit or Fixing Unit. Check the surface of the Pressure Roller and Heater Roller in the Fixing Unit., also check the surface of Developer Roller if the are scratches or other kind of damage on them. In some cases you need only to clean the printer inside with vacuum cleaner. Be careful not to produce any damage to the printer components. Do not touch Drum surface or Developer roller.
Jan 26, 2015 | Office Equipment & Supplies
My copier is producing dirty copies what can i do
Try to see if you have put original toner, than try to see if the cleaning blade has finished its life and can not clear the drum, than see if the developer need to be changed...
it is from many factors but this you have to check that are can more happen.
Aug 05, 2010 | Ricoh Aficio 450 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
Light copies
The optics need to be cleaned also. If you are tech savvy, then there are two screws that hold down the glass on the right side of the top of the copier. lift up the glass, power must be off. then with a soft cloth, wip the mirrors that you can see. Other wise the corona wires will need to be cleaned in side the copier.
Jul 06, 2008 | Canon NP 6050 Copier
Ricoh FT5832 Copier Logo
207 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
