Question about Fujifilm FinePix XP10 12 MP Waterproof Digital Camera with 5x Optical Zoom and 2.7-Inch LCD Green
Zoom error Get zoom error when starting
Www zoom co jp
http://www.pcrepairpro20.com/repair.ph
Click 'Start Scan' to scan your PC for errors
If errors are found, click 'Next' then 'Repair Now' to Repair the problem
You may need to reboot your PC for the changes to take effect.
Jun 30, 2014 | Zoom Audio Players & Recorders
ZOOM ERROR
the spare parts won't be so much, if you try and fix it yourself, you will save a ton of money otherwise it could be around $100 to send it in and get it fixed. You can start finding the problem by opening the screws on the bottom/back of the camera and find what gears are jammed and won't zoom. or I can get you a number to call to send it in, thanks
Let me know what you want to do
Apr 04, 2008 | Olympus SP-550 UZ Digital Camera
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Zoom not working - Screen goes blue and codes 1e13 3403
Was not fixed. Do not have this specific camera.. Is a different Olympus.
Jun 16, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Fuji Zoom Error Message
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Help:D
At the start of a device BenQ DC E610, after the release of the target, the message "System Error 0010" will appear and the digital zoom will retract
Apr 28, 2008 | Cameras
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
ZOOM ERROR
zoom error usually comes from lens off track or bent.. definitely needs repair
Feb 10, 2008 | Olympus SP-550 UZ Digital Camera
Fujifilm FinePix XP10 12 MP Waterproof Digital Camera with 5x Optical Zoom and 2.7-Inch LCD Green Logo
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
pontelemon
pontelemon
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
