The I.R. 2135Ti or TiMAX has some known issues with the trigger o-ring (item# 22A) swelling, the throttle valve (item# 28D) bending or breaking, and the throttle valve seal (item# 28E) wearing out or deteriorating. Procedure wise you should not be able to remove the trigger without first removing the inlet bushing assembly (item# 26) the reason is that the reverse valve (item# 24) keeps the throttle valve from tipping forward and releasing the trigger, there is a slot for the stem of the throttle valve to slide into.
Follow this link to the parts list:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/45534070_ed3.pdf
When reassembling the tool first install the inlet bushing assembly and then install the trigger, make sure to lube the o-ring before inserting.
