Question about Home
Porcher cygnet Toilet keeps running after flushing
brighthm
  • 36 Answers
SOURCE: not enough water in the toilet bowl
Adjust the floating stopper in the tank to allow more water to fill the tank
Posted on Oct 29, 2008
kachbibi1
  • 979 Answers
SOURCE: Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Posted on Jan 28, 2009
co7196
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
After flushing the water filling mechanism does not refill the cistern
then replace the mechanism we can not do it for you .
Sep 30, 2017 | Porcher Home
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
Feb 19, 2015 | Porcher Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Our Porcher veneto 1 piece toilet does not flush. Does porcher have recommended repair service near zip code 94901 ?
I have three of these beautiful babies from when I redid my bathrooms back in the early 2000s -- and one of them started to leak (would keep flowing a small amount into the bowl after filling the tank), so I did some online sleuthing and came across the parts as well as the how-to for a complete rebuild of the critical parts -- and rebuilt all three and they work like new. I am in zip code 94552 so if you need help from a licensed general contractor -- give me a call at 510-909-8813 and I can see if I can fix it for you (for a charge, of course).
Sep 12, 2012 | Porcher Toilet Onepiece Veneto ...
Where do I get porcher 83420
Hello--
That particular model has been disontinued; however, you may want to contact Customer Service to see if there are any spare parts in stock.
http://www.porcher-us.com/contact.aspx
Paul, ASB
Sep 20, 2011 | Porcher 83420-00.000 L'Expression Toilet...
My porcher toilet wont flush.... Push the buttons but nothing happens, have managed to open the top successfully and can manually flush by pushing on the ballcock but buttons still not working.... any...
Hello:
Please feel free to call Customer Service 1-800-359-3261
General Customer Service
Monday through Friday
8:00 A.M. to 7:30 P.M. EST
Technical Customer Service
8:00 A.M. to 6:00 P.M. EST
8:00 A.M. to 3:00 P.M. EST
Customer Care at Porcher Porcher Customer Care
P.O. Box 6820
1 Centennial Plaza
Piscataway, NJ 08855-6820
All the Best,
Paul, -ASB
Sep 12, 2011 | Porcher Home
Need to gt the top off of a porcher toilet we can't fogure out how to get into the tank to fix whatever continues to run
I'm not sure why this is a challenge. The lid should just lift right off unless you have a wall mount toilet. Here is a .pdf of a typical Porcher toilet and how it all goes together. There is also a handy trouble shooting guide. If the toilet is running the culprit is either a faulty flapper or fill vavle. Let me knwo if I can be of any further help.
http://www.porcher-us.com/assets/documents/porcher/install/Install_3337.pdf
Jul 31, 2010 | Home
I have a Porcher one-piece toilet with a bad gasket. How do I take it apart and replace the gasket?
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Jan 05, 2010 | Porcher 40050 Classic Elongated Toilet...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
