Lg wm2501hva leaking water
Leaking water
cresguy
  • 75 Answers
SOURCE: leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Posted on Jul 25, 2008
landsend
  • 1066 Answers
SOURCE: water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Posted on Mar 12, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 23 Answers
SOURCE: My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Posted on Sep 14, 2009
rickead1
  • 1998 Answers
SOURCE: LG WD1238C front loader water is leaking out of
The cause of this is almost always something blocking between the outlet of the dispenser housing
usually it is the large hose that goes from the dispenser to the top of the tub itself if you remove the 2-3 screws along the back of the machine and slide the top cover towards the rear of the machine and then remove the top cover completly this will give you access to this area Usually you will find a large soap deposit or debris stuck in this hose or near the outlet of the soap dispenser housing itself . You have to remove the top cover in order to physicly clean and check these areas if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
Posted on Jun 21, 2011
Water leaking on the floor from back of my lg 25975st
The water supply lines could be leaking or loose. The fill valve could be leaking.
Aug 07, 2016 | LG Washing Machines
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
May 21, 2016 | LG Washing Machines
Lg refrigerator not dispensing water valve in door leaking when prees button
Seals in water valve are likely leaking. Disassemble rebuild or replace water valve .
www.lg.com/us/support/refrigerators
www.lg.com/us/support/parts-accessories
Jun 06, 2015 | LG Refrigerators
LG twintub- water leaking at the spinner onto motor
This is due to failure of the seal on the tub and also if the spindle/bearing seal is also faulty. you need to remove and reset the assembly once again.
Click for tips: Bearings
Feb 01, 2013 | LG Washing Machines
Lg washer wm2501HVA light stays on
why my lllLG washer WM2501hva light stay on ????
Jan 29, 2012 | Washing Machines
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Sep 13, 2009 | LG Washing Machines
Water leaking after i have installed a new drain pump in LG
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
