Question about Motorola Talkabout T5420 (14 Channels) 2-Way Radio
Unit won't turn on. Battery indifferent.
Motorola T5420 premium walkie talkie: One radio turns on, the other won't. Swapping batteries did not change anything.
  • Bob Taylor
    Bob Taylor May 20, 2009
    I bought these phones at a yard sale for $2.00, One phone powered up, the other did not. Of course the first thing you think is battery; right? Interestingly swapping the battery with the working phone made no difference, the unit still would not turn on. After a close inspection, I noticed variation in the way and the shape in which the battery contactors were bent to make contact. I used a small knife point and re-shaped the contacts into more of a vee shape, just like the ones on the working unit, I replaced the battery and the unit still did not turn on. I tried swapping batteries again and whala! the unit powered up and worked perfectly. (accidently hit enter. Sorry, the post above was not edited or completed) So not only was a battery non functional, the contact tabs were not making full contact with the battery. I found two new 1400mAh batteries online for $30.00. Total invested = $32.00 with batteries that last twice as long. I believe this was a result of the radio being dropped.
  • 21 Answers
I bought these phones at a yard sale for $2.00, One phone powered up, the other did not. Of course the first thing you think is battery; right? Interestingly swapping the battery with the working ohone made no difference, the unit still would not turn on. After a close inspection, I noticed variation in the way and the shape in which the battery contactors were bent to make contact. I used a snall knife point and re-shaped the contacts into more of a vee shape, just like the ones on the working unit, I replaced the battery and the unit still did not turn on. I tried swapping batteries again and whala; the unit powered up and worked perfectly,
Posted on May 20, 2009
Can you use a Motorola T5420 with a T5500?
Yes. You would only need to select the same channel and have the interference code set to the same setting on each radio.
Here is a link to the user guides: http://content.giantintl.com/manuals/Moto/T5300_T5400_User_Manual_E.pdf
http://content.giantintl.com/manuals/Moto/T55xx.pdf
Best regards.
Oct 29, 2014 | Motorola Walkie Talkie 2-Way Radio
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
My xtnid 554 turns on but has no display
Check your battery pack. The display is one of the first things to go when using a bad or poorly charged battery. Test by trading batteries with another known good unit. If this does not solve the problem, your display is bad.
Apr 10, 2014 | Motorola Walkie Talkie 2-Way Radio
. Keeps shutting off
This is a sign of a bad or low battery. Try swapping batteries with a known good unit to see if the problem is solved. It takes more energy to transmit than to receive, so as you described a radio can receive messages, but then when you go to transmit and use more energy the battery will not have enough power to do so.
Best regards.
Apr 01, 2014 | Motorola MR350R Two Way Radio
Everytime i press my PTT button on my motorola talkabout Walke Tocke (Sorry if i spell things wrong) it turns off. I dont know how to fix this, it says it has full battery but it just turns off and im...
Your battery may be fully charged but defective. To test try swapping the battery from a known good unit into the radio and see if you have the same problem. Check your battery contacts, and clean with a pencil eraser if needed. If these do not solve the problem, your radio is likely bad.
Best regards.
May 27, 2012 | Motorola Walkie Talkie 2-Way Radio
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
Problem unknown
Hello rixonsusu,
In situations where one radio cannot talk to another radio the problem is often caused by improper setting of the radio's Continuous Tone Coded Squelch System (CTCSS), which Motorola calls "Privacy Codes." (Other manufacturers might use different names, such as Kenwood calling this feature "Quiet Tones.")
When CTCSS is activated your radio's receiver will be muted unless the radio receives a signal from another radio using the required Privacy Code. This prevents you from having to listen to other user's conversations on what can be busy channels with a lot of activity.
In one of your radios has CTCSS enabled and the other does not, or if the other radio is set to the wrong CTCSS tone, the situation you describe will occur: one radio will be able to talk to the other, but that radio will not be able to talk back.
Make sure both of your radios are set to the same CTCSS privacy code or that CTCSS is turned off on both radios.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola Talkabout T5420 (14 Channels) 2-Way Radio Logo
405 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
