Question about Sharp AR-275 Copier
Sharp AR-275 Copier
We have a Sharp AR-275 Copier and I'm looking for the maintenance reset code. I have already cleaned the machine and do not currently have a maintenance contract for our copier. Hope you can help,
Thanks
Laura
  • Anonymous Mar 18, 2014
    how can I fix this or reset copier
    President:
  • Sharp Master
  • 990 Answers
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
Posted on May 30, 2009
F2-02with sharp ar-275
Toner supply abnormality
check toner motor and DV mag sensor
Jun 14, 2014 | Sharp AR-M237 Copier
Sharp copier repair code F5-02
Here is a list of all Sharp Copier Error Codes
The Sharp AR-M205 is almost 12 years old now. It will be very hard to find parts for that machine unless you can find a low meter on ebay.
You may want to take a look here at some of the current Sharp copier models. It looks like the Sharp MX-M232 replaced this machine.
Oct 29, 2012 | Sharp AR-M205 Copier
What does code u2-40 mean and how do i by pass it
Hello, You can download the manual here http://sharp.diplofix.com/forum-SHARP/AR-275
It looks like this error is a CRUM chip error, which could be caused by the type of toner cartridge you are using, and or the actual CRUM chip. The connector could be bad (check the connector for the toner cartridge) or when you replaced the toner cartridge; it may have bent the plate that it is mounted on and it needs to be straightened, realigned.
Oct 07, 2010 | Sharp AR-275 Copier
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Sep 20, 2010 | Sharp AR-275 Copier
Error code L6-10 on sharp ar-275
try to reset or replace the polygon motor
Nov 17, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-275 Copier Logo
327 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
