Question about Sharp UX P200 Plain Paper Thermal transfer Fax
How to delete outgoing message on sharp ux266
How to reset the ongoing answer back to the manufacturer's outgoing message
Once the manufacturers message is deleted it is not available unless it was stored elsewhere.It will be best to check with your dealer to confirm on this or you can always get someone to mime the same tone voice.
Mar 11, 2012 | Lands Phones
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
Nokia c5 cannot delete outbox messages & cnnot send txt. an error ocurred as massages corrupted
Check to see if you have it set to save all outgoing text messages, and if so, it may be full. Try deleting saved messages.
Feb 24, 2011 | Cell Phones
My phono has a full memory how i reset this
Try deleting saved messages,, inbox, drafts, then delete pictures you have downloaded, then delete unused themes etc. You have probably filled it up with one of those or all. Turn off autosave outgoing texts and clean out messages, pictures etc regularly.
How do i record my own message
Recording Outgoing Messages:
1. Hold the ANNC-DAYand speak clearly into the microphone.
2. Release the ANNC-DAY when you finish. Your answering machine beeps and automatically plays back your recorded message.
Message limit:
60 seconds
To re-activate pre-recorded message:
Press "delete" during while playing your outgoing message. The pre-recorded message is now activated.
Feb 21, 2011 | Radio Shack (43-3829) Digital Answering...
How to record Outgoing Message on Answer machine of BINATONE FUSION 2210 DECT phone? Thanks
hi,
if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT phone, his the step you will follow.
to turn A/M on press R then 5.
to turn A/M off press R then 6.
if you want to record Outgoing Message, press R then 1.
After beep record your message.
Press 0 when you have finished your message, then C to return to standby mode.
To listen to incoming messages, press R then 8.
New messages are then played back.
Press 4 to delete message.
thanks for using fixya
Jun 05, 2010 | Lands Phones
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 | Cell Phones
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
Sharp UX P200 Plain Paper Thermal transfer Fax Logo
16 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
