Question about 2-way Remote Transmitter - Dark Navy/gray
How do I reset my remote start?
I can lock the doors and unlock them but I can't get it to start my truck.
    Problem Solver:
  • 5 Answers
While in range of vehicle, press and hold lock and trunk at same time until you hear or see a confirmation on remote to exit valet mode or
Posted on Aug 15, 2014
All my remotes won't unlock passenger doors, why?
this is a problem that can appear after your car battery died, cause the car didn't reset propely, so taking the battery out and putting it back in or letting your car die again would do the trick. I tried a lot of reprogramming procedured for my remote key, none of them worked, what did the trick though was simply unlocking the doors via the all door unlock button on the passenger side door, so simple.
Apr 27, 2012 | Cars & Trucks
Drivers door will not unlock with the remote drivers door will not lock via internal button drivers door does not lock once car above 10 mph all other locking/unlocking functions ok recently had...
That sounds more like the lock actuator inside the door is bad since it does not function in any mode.You can call a dealer to ask about the possibility of a remote reset.Is this a Mini Cooper?It is listed under mini but I would think they would use the full name.If the remote can't be done and you want to self-repair,just comment to this post and I will get an auto link and I will try to describe how to get inside your door.Good luck! Greg
Aug 28, 2010 | Mini Cooper S Cars & Trucks
Central Locking does not work
You must reset your remote control in order for the lock/unlock to work properly.
To reset remote you would:
1)Insert Key in Ignition Turn to Position 1(Don't Start the Engine) for about 5 seconds
2)Turn Key Off and HOLD the LOCK button on Remote while pressing the UNLOCK 3 TIMES
3)Release both lock and unlock buttons you are holding
4)All doors should automatically unlock
And exit the door and lock with the Remote.
Sep 19, 2009 | 2000 BMW 3 Series
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Battery was dead. I jumped started the 05 vw
press and hold lock button on remote while pointing it at the senser.
Jul 06, 2009 | 2000 Volkswagen Jetta TDI
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Un work of the doors auto control lexus
4. Shut door.
5. Open door.
10. Close the door.
11. Open the door.
13. Close the door
Long beep to follow if successful.
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
I can't disable my anti theft device on my chevy malibu 2004 and my car will not start
This usually works.Lock the doors with the remote.Press lock twice sounding the alarm.Then press the unlock button twice.Your car should start now.If that doesnt work try this,Lock the car again with the remote once.Go over to the passenger side door and use the key to unlock the door then press in the door unlock all doors.Hopefully by now it worked.Now if none of these work your security probably malfunctioned and theres only two things that will work,One is disconnecting the battery for 5 mins then reconnecting.unlock doors.the start.If that doesnt work you'll have to take it to the dealer to get the security reset or replaced.The steps I have wrot you are the diagnostics to reset it.I hope these work for you and good luck.See ya had have a great day..
Mar 31, 2009 | 2004 Chevrolet Malibu
Security will not reset
The disarm switch on the latch inside the door is most likely defective, pull the door panel and test it for proper function.
Oct 01, 2008 | 1992 Cadillac Seville
2-way Remote Transmitter - Dark Navy/gray Logo
403 people viewed this question
Top Compustar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Compustar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
