Question about HP Photosmart C5280 Printer
Print labels I am trying to print shipping labels and don't know how to change the setting on my computer. I have labels that come two to a 8.5 x 11 page so 5.5 x 11. I have no idea how to mess around with my printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Use MS Access to make labels wich have template for that.
Posted on Dec 30, 2013
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
  • 1019 Answers
SOURCE: Alignment wrong when using label stationery - OK with plain paer
open the related word document.
select 1 line above the Text in question, press enter twice.
That way, the text will drop by 2 lines.
try a test page on this, alternatively try using a different label layout, until you get the desired result.
Other than the AveryL7160.
Mike @ Compurepair.
Posted on Feb 25, 2008
PeteG0429
  • 34 Answers
SOURCE: prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Posted on Apr 01, 2009
  • 42 Answers
SOURCE: HP laserjet 1020 one page only when usinga printserver.
buy a gdi capable print server like a
Trendnet TE100-P21
http://www.trendnet.com/products/proddetail.asp?prod=145_TE100-P21&cat=46
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: hp laserjet p3015 pausing after 5 or so pages
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Posted on Aug 16, 2010
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Oct 15, 2014 | Avery 8168 Inkjet Labels Shipping...
2348 manuals
try to reset printer to factory default. dowload the seagullscientific drivers and reset from there, much easier. hope it helps, Paulo.
Mar 27, 2014 | Zebra Office Equipment & Supplies
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
I have a Ribbon In Warning but I don't know how to change to Thermal Transfer on Driver. where do I do this? Can't find on menu on front panel
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
Jun 16, 2011 | Zebra S4M Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Oct 20, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Military Shipping Labels
If your not getting an error message I would suspect that the margins have somehow been set beyond the printable area. I don't know what the width on a "Military Shipping Label" is but I've had issues with Zebra label printers printing on the very edges of the labels.
Jul 23, 2008 | Office Equipment & Supplies
Label Printing Issue
Send the shipping label to the printer first in your software.
This isn't a printer issue. It only prints stuff in the order received.
Steve W.
LazerTek, LLC
Jul 02, 2008 | Zebra 140XiIII Plus Thermal Label Printer
2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
HP Photosmart C5280 Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
